Datasheet PE-53829 (Pulse Electronics)
| Manufacturer | Pulse Electronics |
| Description | Power Inductor |
| Pages / Page | 4 / 1 — Turns Ratio. Pulse. National. Nominal. Package. THT Part. SMT Part. Part. … |
| File Format / Size | PDF / 691 Kb |
Turns Ratio. Pulse. National. Nominal. Package. THT Part. SMT Part. Part. Rated. Max. DCR. Number. Inductance. Current. ETOP. Through. Surface. Lead. Hole
SMT Power Inductor Toroid - Designed for National’s 150kHz Simple Switcher™ Tested and recommended by National Semiconductor Base material meets flammability requirements of UL 94V-0 Available in surface mount and through hole versions Electrical Specifications @ 25°C - Operating Temperature -40°C to +125°C
Turns Ratio Pulse Pulse National Nominal Package THT Part SMT Part Part Nominal Rated Max DCR Number Number Number Inductance Current ETOP
(Ω)
Through Surface Lead
(µH) (ADC) (V-µSec)
Hole Mount Diameter PE-53801NL * PE-53801SNL
LM259X-L1 259 0.13 23.1 3.4 LP-25 LCI-20 -
PE-53802NL PE-53802SNL
LM259X-L2 178 0.16 16.5 2.8 LP-25 LCI-20 -
PE-53803NL PE-53803SNL
LM259X-L3 118 0.2 13.2 1.8 LP-25 LCI-20 -
PE-53804NL * PE-53804SNL *
LM259X-L4 79 0.25 9.9 1.5 LP-25 LCI-20 -
PE-53805NL * PE-53805SNL *
LM259X-L5 55 0.3 6.6 1.0 LP-25 LCI-20 -
PE-53806NL * PE-53806SNL
LM259X-L6 39 0.34 6.6 .80 LP-25 LCI-20 -
PE-53807NL PE-53807SNL *
LM259X-L7 26 0.45 6.6 .62 LP-25 LCI-20 -
PE-53808NL PE-53808SNL
LM259X-L8 374 0.2 75.9 2.7 LP-30 LCI-30 -
PE-53809NL PE-53809SNL
LM259X-L9 256 0.25 33 2.2 LP-30 LCI-30 -
PE-53810NL PE-53810SNL
LM259X-L10 176 0.3 26.4 1.4 LP-30 LCI-30 -
PE-53811NL PE-53811SNL
LM259X-L11 118 0.38 19.8 1.2 LP-30 LCI-30 -
PE-53812NL PE-53812SNL
LM259X-L12 78 0.46 16.5 0.8 LP-30 LCI-30 -
PE-53813NL * PE-53813SNL
LM259X-L13 55 0.56 13.2 0.5 LP-30 LCI-30 -
PE-53814NL PE-53814SNL
LM259X-L14 39 0.68 9.9 0.3 LP-30 LCI-30 -
PE-53815NL * PE-53815SNL
LM259X-L15 26 0.84 6.6 0.2 LP-30 LCI-30 -
PE-53816NL PE-53816SNL
LM259X-L16 17 1.02 6.6 0.1 LP-30 LCI-30 -
PE-53817NL PE-53817SNL
LM259X-L17 375 0.36 75.9 1.3 LP-37 LCI-37 -
PE-53818NL PE-53818SNL
LM259X-L18 252 0.44 49.5 0.9 LP-37 LCI-37 -
PE-53819NL PE-53819SNL
LM259X-L19 173 0.54 36.3 0.6 LP-37 LCI-37 -
PE-53820NL PE-53820SNL
LM259X-L20 115 0.67 29.7 0.4 LP-37 LCI-37 -
PE-53821NL PE-53821SNL
LM259X-L21 78 0.82 23.1 0.3 LP-37 LCI-37 -
PE-53822NL PE-53822SNL
LM259X-L22 54 1.0 16.5 0.2 LP-37 LCI-37 -
PE-53823NL PE-53823SNL
LM259X-L23 38 1.2 13.2 0.1 LP-37 LCI-37 -
PE-53824NL * PE-53824SNL
LM259X-L24 26 1.48 9.9 0.1 LP-37 LCI-37 -
PE-53825NL PE-53825SNL
LM259X-L25 18 1.81 9.9 0.06 LP-37 LCI-37 - Power.PulseElectronics.com SPM2007_47 (08/20) 1
