Datasheet MMBFJ201 (Fairchild) - 8
ManufacturerFairchild
DescriptionN-Channel General Purpose Amplifier in SOT-23 Package
Pages / Page13 / 8 — TO-92 Tape and Reel Data, continued. TO-92 Tape and Reel Taping Dimension …
File Format / SizePDF / 640 Kb
TO-92 Tape and Reel Data, continued. TO-92 Tape and Reel Taping Dimension Configuration:. H1 HO. P1 F1. ITEM DESCRIPTION. SYMBOL
TO-92 Tape and Reel Data, continued TO-92 Tape and Reel Taping Dimension Configuration: H1 HO P1 F1 ITEM DESCRIPTION SYMBOL
Figure 4.0
Hd P Pd b Ha W1 d S L H1 HO L1 WO t W2 W t1 P1 F1 P2 DO ITEM DESCRIPTION SYMBOL DIMENSION PO
Base of Package to Lead Bend b 0.098 (max) Component Height Ha 0.928 (+/- 0.025)
User Direction of Feed
Lead Clinch Height HO 0.630 (+/- 0.020) Component Base Height H1 0.748 (+/- 0.020) Component Alignment ( side/side ) Pd 0.040 (max) Component Alignment ( front/back ) Hd 0.031 (max) Component Pitch P 0.500 (+/- 0.020) Feed Hole Pitch PO 0.500 (+/- 0.008) Hole Center to First Lead P1 0.150 (+0.009, -0.010) Hole Center to Component Center P2 0.247 (+/- 0.007) Lead Spread F1/F2 0.104 (+/- 0 .010) Lead Thickness d 0.018 (+0.002, -0.003) Cut Lead Length L 0.429 (max) Taped Lead Length L1 0.209 (+0.051, -0.052) Taped Lead Thickness t 0.032 (+/- 0.006) Carrier Tape Thickness t1 0.021 (+/- 0.006) Carrier Tape Width W 0.708 (+0.020, -0.019)
TO-92 Reel
Hold - down Tape Width WO 0.236 (+/- 0.012) Hold - down Tape position W1 0.035 (max)
Configuration:
Figure 5.0 Feed Hole Position W2 0.360 (+/- 0.025) Sprocket Hole Diameter DO 0.157 (+0.008, -0.007) Lead Spring Out S 0.004 (max) Note : All dimensions are in inches. ELECT ROSTATIC SEN SI TIVE D EVICES
D4 D1 ITEM DESCRIPTION SYSMBOL MINIMUM MAXIMUM D2
Reel Diameter D1 13.975 14.025
F63TNR Label
Arbor Hole Diameter (Standard) D2 1.160 1.200
Customized Label
(Small Hole) D2 0.650 0.700 Core Diameter D3 3.100 3.300 Hub Recess Inner Diameter D4 2.700 3.100 Hub Recess Depth W1 0.370 0.570 Flange to Flange Inner Width W2 1.630 1.690
W1
Hub to Hub Center Width W3 2.090
W2 W3
Note: All dimensions are inches
D3
July 1999, Rev. A
