Datasheet FGD3050G2V (ON Semiconductor) - 8
| Manufacturer | ON Semiconductor |
| Description | Ignition IGBT, 500V, 27A, 1.3V, 300mJ, DPAK EcoSPARK II, N-Channel Ignition |
| Pages / Page | 9 / 8 — DPAK3 6.10x6.54x2.28, 2.29P. GENERIC. MARKING DIAGRAM*. Discrete. … |
| File Format / Size | PDF / 602 Kb |
DPAK3 6.10x6.54x2.28, 2.29P. GENERIC. MARKING DIAGRAM*. Discrete. DOCUMENT NUMBER: 98AON10527D. DESCRIPTION:. PAGE 2 OF 2. onsemi
CASE 369C ISSUE J DATE 12 AUG 2025
GENERIC MARKING DIAGRAM*
XXXXXXG AYWW ALYWW XXX XXXXXG
IC Discrete
XXXXXX = Device Code A = Assembly Location L = Wafer Lot Y = Year WW = Work Week G = Pb−Free Package *This information is generic. Please refer to device data sheet for actual part marking. Pb−Free indicator, “G” or microdot “G”, may or may not be present. Some products may not follow the Generic Marking. STYLE 1: STYLE 2: STYLE 3: STYLE 4: STYLE 5: PIN 1. BASE PIN 1. GATE PIN 1. ANODE PIN 1. CATHODE PIN 1. GATE 2. COLLECTOR 2. DRAIN 2. CATHODE 2. ANODE 2. ANODE 3. EMITTER 3. SOURCE 3. ANODE 3. GATE 3. CATHODE 4. COLLECTOR 4. DRAIN 4. CATHODE 4. ANODE 4. ANODE STYLE 6: STYLE 7: STYLE 8: STYLE 9: STYLE 10: PIN 1. MT1 PIN 1. GATE PIN 1. N/C PIN 1. ANODE PIN 1. CATHODE 2. MT2 2. COLLECTOR 2. CATHODE 2. CATHODE 2. ANODE 3. GATE 3. EMITTER 3. ANODE 3. RESISTOR ADJUST 3. CATHODE 4. MT2 4. COLLECTOR 4. CATHODE 4. CATHODE 4. ANODE
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: DPAK3 6.10x6.54x2.28, 2.29P PAGE 2 OF 2 onsemi
and are trademarks of Semiconductor Components Industries, LLC dba
onsemi
or its subsidiaries in the United States and/or other countries.
onsemi
reserves the right to make changes without further notice to any products herein.
onsemi
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does
onsemi
assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
onsemi
does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2011 www.onsemi.com
