Datasheet TFPT (Vishay)
ManufacturerVishay
DescriptionTemperature Dependent Nickel Thin Film Chip Resistor (RTD)
Pages / Page5 / 1 — TFPT. Temperature Dependent Nickel Thin Film Chip Resistor (RTD). …
File Format / SizePDF / 121 Kb
TFPT. Temperature Dependent Nickel Thin Film Chip Resistor (RTD). FEATURES. LINKS TO ADDITIONAL RESOURCES. APPLICATIONS
Datasheet TFPT Vishay
TFPT
TFPT
www.vishay.com Vishay
Temperature Dependent Nickel Thin Film Chip Resistor (RTD) FEATURES
• Alumina substrate base with nickel based PTC thin film element • 0603, 0805, and 1206 sizes available • Available in tape and reel packaging • Standard R25 tolerances: ± 0.5 %, ± 1 %, ± 5 % • Operating temperature range: -55 °C to +150 °C • High stability over the entire temperature range • C-UL-US recognized, file E148885 • AEC-Q200 qualified (grade 1) • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
LINKS TO ADDITIONAL RESOURCES APPLICATIONS
Temperature compensation and sensing in • Automotive
Design Tools Models
• Motor drives • Lighting LED drivers • Test and measuring equipment
QUICK REFERENCE DATA PARAMETER VALUE UNIT DESCRIPTION TFPT0603 TFPT0805 TFPT1206
Resistance value at 25 °C (1) 100 to 1K 100 to 5K 100 to 10K Ω Tolerance on R25-value ± 0.5; ± 1; ± 5 % TCR at 25 °C 4110 ppm/K Tolerance on TCR at 25 °C (2) ± 400 Operating temperature range: at rated power -55 to +70 °C at derated power (3) -55 to +150 Storage temperature range -55 to +150 °C Dissipation factor δ (for information only) (4) 1.8 2.3 4 mW/K Maximum rated power at 70 °C (P70) (3)(4) 75 100 125 mW Maximum working voltage RCWV (5) 30 40 50 V Weight 2 5.5 10 mg Failure rate FITobserved ≤ 0.1 x 10-9/h
Notes
(1) Other R25-values are available upon request (2) Contact Vishay if closer TCR lot tolerance is desired (3) Derated power curve can be found in section “Power Derating”. Power applied at maximum temperature should not let increase the film temperature by more than 1 K (1 °C) (4) Valid for sensor element only in low dissipative mode. For dissipative mounting, please refer to APPLICATION INFORMATION (5) Rated continuous working voltage is maximum working voltage or P x R whichever is less 70
When the TFPT dissipates power, a temperature rise above the ambient temperature occurs, dependent on the thermal resistance of the assembled thermistor together with the mounting substrate. The (de)-rated power dissipation applies only if the long term permitted film temperature of 150 °C is not exceeded by more than 1 °C. Typically the thermal resistance (RthFA) of a FR4 mounted TFPT0603 is around 250 K/W. Please consider the application note “Thermal Management in Surface-Mounted Resistor Applications” (www.vishay.com/doc?28844) for information on the general nature of thermal resistance. Revision: 25-Feb-2025
1
Document Number: 33017 For technical questions, contact: nlr@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
