Datasheet XL4016 (XLSemi)
ManufacturerXLSemi
Description12A 180KHz 40V Buck DC to DC Converter in TO220-5L Package
Pages / Page10 / 1 — Datasheet. 12A. 180KHz. 40V. Buck. DC. to. DC. Converter. XL4016. …
File Format / SizePDF / 445 Kb
Datasheet. 12A. 180KHz. 40V. Buck. DC. to. DC. Converter. XL4016. Features. General. Description. Recommended. operating. voltage. range. The. XL4016. is. a. 180
Datasheet XL4016 XLSemi
Datasheet 12A 180KHz 40V Buck DC to DC Converter XL4016 Features General Description Recommended operating voltage range The XL4016 is a 180 KHz fixed frequency 8V~36V PWM buck (step-down) DC/DC converter, Output Adjustable from 1.25V to 32V capable of driving a 12A load with high Maximum Duty Cycle 100% efficiency, low ripple and excellent line and Minimum Drop Out 0.3V load regulation. Requiring a minimum Fixed 180KHz Switching Frequency number of external components, the 12A Constant Output Current Capability regulator is simple to use and include Internal Optimize Power MOSFET internal frequency compensation and a High efficiency up to 96% fixed-frequency oscillator. Excellent line and load regulation Built in thermal shutdown function The PWM control circuit is able to adjust the Built in current limit function duty ratio linearly from 0 to 100%. An over Built in output short protection function current protection function is built inside. Available in TO220-5L package When short protection function happens, the operation frequency will be reduced from 180KHz to 48KHz. An internal compensation block is built in to minimize external component count. Applications LCD Monitor and LCD TV Portable instrument power supply Telecom / Networking Equipment Figure1. Package Type of XL4016 Rev 1.6 www.xlsemi.com 1
