Datasheet AWMF-0247 (Qorvo)
ManufacturerQorvo
DescriptionKu-band Quad 4.0 x 2.0 Rx Beamformer IC
Pages / Page3 / 1 — Preliminary Data Sheet Brief. AWMF-0247. Ku-band Quad 4x1 Tx/Rx …
File Format / SizePDF / 761 Kb
Preliminary Data Sheet Brief. AWMF-0247. Ku-band Quad 4x1 Tx/Rx Beamformer IC. 1. Product Overview and Benefits
Datasheet AWMF-0247 Qorvo
Preliminary Data Sheet Brief AWMF-0247
Ku-band Quad 4x1 Tx/Rx Beamformer IC 1. Product Overview and Benefits
The Ku-band AWMF-0247 adds TDD half-duplex capability to Qorvo’s beamformer IC portfolio, enabling both transmit and receive in a single device. This al ows flat panel SATCOM terminals to use a shared antenna aperture, cutting system size and component count compared to dual-antenna designs. With support for four elements across 13.75 to 14.5 GHz (Tx) and 10.7 to 12.75 GHz (Rx), the AWMF-0247 combines adjustable PA bias for efficient linear transmit power with low 3.0 x 3.8 mm FC-CSP noise figure for improved receive sensitivity. The result is a compact, power-efficient solution ideal for LEO and NTN terminals.
3. Key Features New Updates:
• 13.75 to 14.5 GHz Tx operation •
TDD architecture
for single aperture antenna design for • 10.7 to 12.75 GHz Rx operation low cost LEO and NTN terminals • Supports 4 antenna elements with fixed polarization • 10 dBm Tx output power per port •
Separate Tx and Rx element feed architectures
for best • 27 dB Tx gain per channel performance • 30 dB Rx coherent gain • Inactive
port impedance management
improves off-state • 6-bit phase control (LSB=5.625°) return loss by >3dB,
increasing aperture efficiency
• 6-bit gain control (LSB=0.25 dB) • Telemetry reporting •
Industry leading NF and DC power
performance •
Higher accuracy
temperature sensing
4. Applications
New FC-CSP
package • SATCOM flat panel terminals • Low-cost LEO
2. Functional Block Diagram
• Emerging NTN
5. Ordering Information Part Number Description
AWMF-0247 AWMF-0247 Tape and reel 7”, Qty 2000 AWMF-0247 Cut tape smal sample, AMWF-0247-SQ Qty 25 AWMF-0247-SR AWMF-0247 Short reel, Qty 100 AWMF-0247 Developer kit for AWMF-0247-DL evaluation, Qty 1 If you need further information about the AWMF-0247, please contact us at beamforming-sales@qorvo.com. AWMF-0247 Data Sheet Rev. B, 2025-09-23 1 of 3 www.qorvo.com Specifications provided are for evaluation purposes only and are subject to change without notice. This product is in pre-production and may not meet the listed specifications. © 2025 Qorvo US, Inc. – Confidential and Proprietary Information – Subject to Non-Disclosure Agreement
