Datasheet P30L (Vishay) - 2
| Manufacturer | Vishay |
| Description | Long Life Potentiometer - 2 Million Cycles, Heavy Duty - Cermet, Fully Sealed |
| Pages / Page | 6 / 2 — P30L. DIMENSIONS. P30LME: Panel sealed. PANEL MOUNT. SHAFT. MODEL. … |
| File Format / Size | PDF / 172 Kb |
P30L. DIMENSIONS. P30LME: Panel sealed. PANEL MOUNT. SHAFT. MODEL. Standard shaft style F (flatted). CONDIFICATION (mm) (mm). Note
P30L
www.vishay.com Vishay Sfernice
DIMENSIONS
in millimeters (inches) ± 0.5 mm (± 0.02")
23 (0.91) max. 16 (0.63) max. Sealing ring 0.7 (0.03) Ø 1.2 Ø 1 (0.4) (0.05) Ø 6 Flats located (0.24) 8 ± 0.2 Ø 19.7 (0.78) (0.31 ± 0.01) Ø 10.5 (0.41) 9 (0.35) FDR = 13 (0.61) FJR = 22 (0.87)
PANEL MOUNT
FPR = 47 (1.85)
SHAFT L l MODEL Standard shaft style F (flatted) CONDIFICATION (mm) (mm)
FGF 16 3.17 Ø 6 5.5 ± 0.05 (0.24) P30LL FLF 25 12 FRF 30 12 FDF 13 3.17 P30LM FJF 22 12 l FPF 47 12
a Note
L • Shaft shown at center position. Flat opposite to the wiper
Standard shaft style S (slotted) SHAFT L MODEL CONDIFICATION (mm)
Ø 6 (0.24) FGS 16
1
P30LL FLS 25 FRS 50 FDS 13 1.8 ± 0.2 P30LM FJS 22
L
FPS 47
L Note L
• Slot aligned to the wiper at ± 10° Revision: 27-Jan-2025
2
Document Number: 51056 For technical questions, contact: sferpottrimmers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
