RV4L www.vishay.com Vishay Sfernice Long Life / Heavy Duty PotentiometerFEATURES • High power rating 2 W at 70 °C • Sealed up to IP 67 • Low contact resistance variation (2 % typical) • Robust nickel plated brass shaft • Use of faston 2.86 connections • Cermet element • Center detent option LINKS TO ADDITIONAL RESOURCES • Test according to IEC 60393-1 D 3 • Long life ≥ 200K cycle 3 D3D ModelsCapabilities andCustom Options • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912 QUICK REFERENCE DATA Multiple module No Switch module n/a Detent module Yes Special electrical laws A: linear Sealing level IP 67 Lifespan 200K cycle DIMENSIONS in millimeters (inches) ± 0.5 mm (± 0.02") 2.85 (0.11) 9.52 (0.37) 20 max. (0.79) 19.6 Ø (0.77) 2 0.5 3 (0.02) (0.12) 5.2 R (0.20) 3 1 ad re th 8 3/8) ( 12 (0.31) 2 L (0.47) EF-2A Ø 6.35 ± 0.08 (1/4 ± 0.031) 76° Ø 9.5 32 UN Length “L” 1/2" 7/8" 2" Shaft code GBS GJS GRS Revision: 18-Sep-2024 1 Document Number: 50079 For technical questions, contact: sferpottrimmers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
