Datasheet RV4L (Vishay) - 2
ManufacturerVishay
DescriptionLong Life / Heavy Duty Potentiometer
Pages / Page5 / 2 — RV4L. ELECTRICAL SPECIFICATIONS. (1). (3). (2)
File Format / SizePDF / 114 Kb
RV4L ELECTRICAL SPECIFICATIONS (1) (3) (2)
RV4L
www.vishay.com Vishay Sfernice
Resistive element Cermet Electrical travel 270° ± 10° Resistance range Linear taper 500 Ω to 5 MΩ Standard series Please refer to table “Standard Resistance Element Data” Standard ± 20 % Tolerance On request ± 10 % Axis Title 100 10000 80 ) (% 1000 60 A ne ne ine Taper standard law: A (linear) (other custom laws upon request) 1st li 2nd l 40 2nd li tal Resistance 100 o T 20 0 10 0 20 40 60 80 100 Clockwise Shaft Rotation (%) Circuit diagram
(1) (3) (2) cw
Axis Title 10000 Linear taper “A” 2 1000 ) ine ne ne r (W e Power rating Linear 2 W at 70 °C w 1st li 2nd l o 1 2nd li P 100 0 10 0 20 40 60 70 80 100 125 140 Ambient Temperature (°C) Temperature coefficient (typical) 300 ppm/°C Limiting element voltage (linear law) 500 V Contact resistance variation (typical) 2 % Rn End resistance 1 Ω Dielectric strength (RMS) 1500 V Insulation resistance (500 VDC) 104 MΩ Independent linearity (typical) 5 % Revision: 18-Sep-2024
2
Document Number: 50079 For technical questions, contact: sferpottrimmers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
