Datasheet RV4L (Vishay) - 4
ManufacturerVishay
DescriptionLong Life / Heavy Duty Potentiometer
Pages / Page5 / 4 — RV4L. PERFORMANCE. TYPICAL VALUES AND DRIFTS. TESTS. CONDITIONS. T/R. T …
File Format / SizePDF / 114 Kb
RV4L. PERFORMANCE. TYPICAL VALUES AND DRIFTS. TESTS. CONDITIONS. T/R. T (%). OTHER. Note. ORDERING INFORMATION. PART NUMBER DESCRIPTION. 20 %
RV4L PERFORMANCE TYPICAL VALUES AND DRIFTS TESTS CONDITIONS T/R T (%) OTHER Note ORDERING INFORMATION PART NUMBER DESCRIPTION 20 %
RV4L
www.vishay.com Vishay Sfernice
Δ
R T/R T (%) OTHER
1000 h at rated power Electrical endurance ± 3 % - 90’/30’ - ambient temp. 70 °C Phase A dry heat 125 °C Phase B damp heat Climatic sequence ± 0.5 % - Phase C cold -55 °C Phase D damp heat 5 cycles 56 days Damp heat, steady state ± 0.5 % Insulation resistance: > 105 MΩ 40 °C, 93 % HR 5 cycles Change of temperature ± 0.5 % -55 °C at +125 °C 200 000 cycles at rated power Mechanical endurance turn angle ± 60° ± 20 % Independent linearity ± 10 % T° = 20 °C 50 g’s at 11 ms Shock ± 1 % 3 successive shocks in 3 directions 10 Hz to 55 Hz Vibration ± 1 % 0.75 mm or 10 g’s at 6 h
Note
• Nothing stated herein shall be construed as a guarantee of quality or durability
(part number)
R V 4 L F L G J S 5 0 2 M A
SHAFT OHMIC MODEL BUSHING OPTION SHAFT TOLERANCE TAPER SPECIAL END VALUE RV4L F = Ø 3/8" L = LPRP GB S = slotted Linear from M = 20 % A = linear CV1M = detent 0 = no GJ 500 Ω to option or locating peg GR On request: 5 MΩ On request: On request: special code AP = R = round K = 10 % custom laws given by Vishay custom F = flatted 502 = 5 kΩ D = knurled shaft (1) or C = custom
Note
(1) See Dimensions table
(for information only)
RV4L F L GJ S 5K 20 % A BO50 e3
SHAFT DETENT LEAD MODEL BUSHING OPTION SHAFT VALUE TOLERANCE TAPER PACKAGING AP N° SPECIAL END OPTION (Pb)-FREE
ACCESSORIES
Additional Accessories (to order separately) www.vishay.com/doc?51051 Control knobs www.vishay.com/doc?51101
RELATED DOCUMENTS APPLICATION NOTES
Potentiometers and Trimmers www.vishay.com/doc?51001 Guidelines for Vishay Sfernice Resistive and Inductive Components www.vishay.com/doc?52029 Capabilities and Custom Options www.vishay.com/doc?48485 Revision: 18-Sep-2024
4
Document Number: 50079 For technical questions, contact: sferpottrimmers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
