Datasheet G9H (Omron) - 7
| Manufacturer | Omron |
| Description | Hybridization of a Magnetic Relay and an SSR Achieves 10-A Switching for 10 Million Operations |
| Pages / Page | 9 / 7 — G9H. Dimensions. Terminal Arrangement/. Mounting Hole Dimensions. … |
| File Format / Size | PDF / 2.2 Mb |
G9H. Dimensions. Terminal Arrangement/. Mounting Hole Dimensions. Internal Connections. PTFZ-08-E (Finger Protection Structure)
G9H Dimensions Terminal Arrangement/ Mounting Hole Dimensions Internal Connections PTFZ-08-E (Finger Protection Structure)
Two, 4.5 dia. or M4 mounting holes Two, 4.5 × 6 7 3.4 mounting holes 8-M3.5×7 2 1 4 3 68±0.3 78.5 max. 35.5 6 5 8 7 19±0.2 (Top View) (Top View) 8 28.5 max. 33 max.
Note:
Track mounting is also possible.
Dimensions Terminal Arrangement/ Mounting Hole Dimensions Internal Connections PT08
5 0.3 25.5 29.5 max. max. 2.7 24 max. 2 25.8±0.2 20.5 max. Eight, 1.7-dia × 3.5 oblong holes
PT08QN
21.4+0.2 0 1.5×1.0 1 2 25.5 29.5 1.0 max. max. 3 4 9 2.5 5 6 2.7 20 1.5 2 35 max. 24 max. 7 8 (Bottom View)
PT08-0
*Maintain a sufficient distance from the pattern when using double-sided PCBs. 2 15.6 • The structure does not resist flux. Manual soldering is recommended for 10 this product. 5.35 0.3 4.6 12.45 29.5 max. 6.45 2 5* 6.5 6.5 1 4.3 3 Eight, 2.5-dia. holes 22 max. (±0.1 tolerance) 18 max.
7
