Datasheet 74AC169 (Fairchild) - 8
ManufacturerFairchild
Description4-Stage Synchronous Bidirectional Counter
Pages / Page8 / 8 — ter. Physical Dimensions. u o C. ional. rect idi. onous B. Stage Synchr
File Format / SizePDF / 114 Kb
ter Physical Dimensions u o C ional rect idi onous B Stage Synchr
ter Physical Dimensions n
inches (millimeters) unless otherwise noted (Continued)
u o C ional rect idi onous B Stage Synchr 16-Lead Plastic Dual-In-Line Package (PDIP), JEDEC MS-001, 0.300” Wide 4- Package Number N16E 9 16 C A 74
Fairchild does not assume any responsibility for use of any circuitry described, no circuit patent licenses are implied and Fairchild reserves the right at any time without notice to change said circuitry and specifications.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems 2. A critical component in any component of a life support which, (a) are intended for surgical implant into the device or system whose failure to perform can be rea- body, or (b) support or sustain life, and (c) whose failure sonably expected to cause the failure of the life support to perform when properly used in accordance with device or system, or to affect its safety or effectiveness. instructions for use provided in the labeling, can be rea- sonably expected to result in a significant injury to the
www.fairchildsemi.com
user. www.fairchildsemi.com 8
