Datasheet LF53464 (Littelfuse)
| Manufacturer | Littelfuse |
| Description | Omni-polar Magnetic Angle Sensor in LGA8L package |
| Pages / Page | 4 / 1 — Datasheet. LGA8L LF53464-08TMR. Description. Features & Benefits. … |
| File Format / Size | PDF / 522 Kb |
Datasheet. LGA8L LF53464-08TMR. Description. Features & Benefits. Additional Information. Resources. Accessories. Samples
Omnipolar TMR
Datasheet LGA8L LF53464-08TMR
Omnipolar Magnetic Sensor
The LF53464-08TMR angle sensor features a dual-axis, orthogonal push-pull Wheatstone bridge architecture. Each bridge integrates four high-sensitivity TMR (Tunnel Magnetoresistor) elements, delivering output voltage of up to 65% of the supply voltage. This strong signal output minimizes the need for external amplification or additional processing circuitry. The sensor also adjusts for ambient temperature variation. When a magnet is positioned above the sensor to create a magnetic field paral el to the chip surface, the chip’s dual-axis output produces voltage signals in a sine/cosine relationship proportional to the angle of the magnetic field. The LF53464-08TMR is offered in a compact LGA8L package, measuring 3 mm × 3 mm × 0.75 mm.
Features & Benefits Additional Information
■ Tunneling Magnetoresistance ■ Low power consumption technology (TMR) ■ Compact Package ■ 0-360˚ angle measurement ■ X-Y axis sensing direction ■ Up to 7V operating range ■ Operates with smaller ■ Differential output magnets for cost reduction
Resources Accessories Samples
■ Excellent thermal stability ■ RoHS and REACH compliant ■ Wider airgap capability
Functional Block Diagram Applications
■ Rotary position sensor ■ Valve position sensors
V V sin cos
■ Rotary encoders ■ Knob position sensors ■ Contactless potentiometers
Sin- Cos- Sin+ Cos+ G G sin cos
© 2025 Littelfuse, Inc.
1
Specifications are subject to change without notice. VL 07/21/25
