Product Brief PI7C9X762Q (Diodes)
ManufacturerDiodes
DescriptionAutomotive I2C-Bus/SPI to UART Bridge Controller with 64 Bytes of TX/RX FIFOs
Pages / Page1 / 1 — Lead-free Green. PRODUCT BRIEF. PI7C9X762Q
File Format / SizePDF / 387 Kb
Product Brief PI7C9X762Q Diodes
A Product Line of
b P
Diodes Incorporated
Lead-free Green PRODUCT BRIEF PI7C9X762Q Automotive I2C-Bus/SPI to UART Bridge Controller with 64 Bytes of TX/RX FIFOs Description Features
y The PI7C9X762Q is a I2C-bus/SPI to a dual-channel high per- AEC-Q100 Grade 2 Compliant y formance UART bridge control er. It offers data rates up to Dual channel full-duplex UART y Supports I2C-bus or SPI interface 33Mbps and guarantees low operating and sleeping current. y 64 bytes FIFO (transmitter and receiver) The PI7C9X762Q also has up to 8 additional programmable y Fully compatible with industrial standard 16C450 and equivalent general purpose I/O [GPIO] pins. The device comes in very y Baud Rates up to 16Mbit/s in 4X sampling clock rate small TQFN32 packages, which makes it ideal y suitable for y Programmable character formatting cost efficient, handheld, battery operated applications. These à 5-bit, 6-bit, 7-bit or 8-bit character UART bridges provide protocol conversion from I2C -bus or à Even, odd, or no parity SPI to RS-232/RS-485/RS-422 and are ful y bidirectional. à 1, 1.5, or 2 stop bits y The PI7C9X762Q supports SPI clock speeds up to 33Mbps Programmable Receive and Transmit FIFO trigger levels y and IrDA SIR up to 1.152Mbit/s. Special character detection y Internal Loopback mode The PI7C9X762Q’s internal register set is backward-compat- y Line break generation and detection ible with the widely used and widely popular 16C450 UART.
Flow Control
The PI7C9X762Q also provides additional advanced features y Supports hardware flow control using RTS/CTS such as auto hardware and software flow control, automatic y Supports software flow control with programmable Xon/Xoff RS-485 support, support for fractional baud rates and soft- characters ware reset. This al ows the software to reset the UART at any y Programmable single or double Xon/Xoff characters moment, independent of the hardware reset signal.
Interface Control
y Automatic RS-485 slave address detection y RS-485 driver direction control via RTS signal y RS-485 driver direction control inversion
Application(s)
y Built-in IrDA encoder and decoder interface y y Telematics Supports IrDA SIR with speeds up to 115.2kbit/s (optional 1.152Mbps) y ADAS y Up to eight user programmable GPIO pins y Smart Cockpits y Software reset y Zonal Gateways
Others
y Central Control ers y Low standby current at 3.3V y Wide operation voltage (1.8V, 2.5V or 3.3V)
Ordering Information
y Automotive temperature ranges -40˚C to 105˚C
I2C Interface
y Compliant with I2C-bus fast speed
Orderable Part Number Package
y Supports slave mode only
Code Package Description
y Crystal oscil ator (up to 24MHz) or external clock (up to 64MHz) input PI7C9X762Q2ZHEX ZH 32-Contact, TQFN (W- QFN5050-32)
SPI Interface
y PI7C9X762Q supports 33 Mbit/s maximum SPI clock speed Notes: y Supports SPI mode 0 (slave mode only) • Q = Automotive Compliant • 2 = AEC-Q100 Grade Level y Packaging (Pb-free & Green): • E = Pb-free and Green à 32-Pin, TQFN (ZH) • X suffix = Tape/Reel y Total y Lead-Free & Ful y RoHS Compliant (Notes 1 & 2) y Halogen and Antimony Free. “Green” Device (Note 3) y The PI7C9X762Q is suitable for automotive applications requiring specific change control; this part is AEC-Q100 qualified, PPAP capable, and manufactured in IATF 16949 certified facilities https:/ www.diodes.com/quality/product-definitions/
Notes:
1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. Automotive products are AEC-Q100 qualified and are PPAP capable. Refer to https://www.diodes.com/quality/. Rev 3 August 2025 diodes.com
