Datasheet DFLS230L (Diodes)
| Manufacturer | Diodes |
| Description | Schottky |
| Pages / Page | 5 / 1 — DFLS230L. Green. 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER. … |
| File Format / Size | PDF / 372 Kb |
DFLS230L. Green. 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER. PowerDI123. Features. Mechanical Data
DFLS230L Green 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER PowerDI123 Features Mechanical Data
Guard Ring Die Construction for Transient Protection Package: PowerDI®123 Low Power Loss, High Efficiency Package Material: Molded Plastic, "Green" Molding Compound. Patented Interlocking Clip Design for High Surge Current UL Flammability Classification Rating 94V-0 Capacity Moisture Sensitivity: Level 1 per J-STD-020 High Current Capability and Low Forward Voltage Drop Terminal Connections: Cathode Band
Lead-Free Finish; RoHS Compliant (Notes 1 & 2)
Terminals: Finish – Matte Tin Annealed Over Copper
Halogen and Antimony Free. “Green” Device (Note 3)
Leadframe. Solderable per MIL-STD-202, Method 208
This part is qualified to JEDEC standards (as references in
Weight: 0.01 grams (Approximate)
AEC-Q) for High Reliability. https://www.diodes.com/quality/product-definitions/ An Automotive-Compliant Part is Available Under Separate Datasheet (DFLS230LQ)
Top View
Ordering Information
(Note 4)
Packing Part Number Package Qty. Carrier
DFLS230L-7 PowerDI123 3000 Tape & Reel Notes: 1. EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. All applicable RoHS exemptions applied. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/.
Marking Information
F03A = Product Type Marking Code YM = Date Code Marking Y = Year (ex: J = 2022) M = Month (ex: 9 = September) Date Code Key
Year 2004 … 2022 2023 2024 2025 2026 2027 2028 2029 2030 2031 Code
R … J K L M N O P R S T
Month Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec Code
1 2 3 4 5 6 7 8 9 O N D PowerDI is a registered trademark of Diodes Incorporated. DFLS230L 1 of 5 July 2022 Document number: DS30515 Rev. 7 - 2
www.diodes.com
© 2022 Copyright Diodes Incorporated. All Rights Reserved.
