Datasheet DFLS230L (Diodes) - 2
| Manufacturer | Diodes |
| Description | Schottky |
| Pages / Page | 5 / 2 — DFLS230L. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal … |
| File Format / Size | PDF / 372 Kb |
DFLS230L. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics. Electrical Characteristics. Min. Typ. Max
DFLS230L Maximum Ratings
(@TA = +25°C, unless otherwise specified.) Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Characteristic Symbol Value Unit
Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM 30 V DC Blocking Voltage VR RMS Reverse Voltage VR(RMS) 21 V Average Forward Current @ TT = +121°C IF(AV) 2.0 A Non-Repetitive Peak Forward Surge Current 8.3ms I Single Half Sine-Wave Superimposed on Rated Load FSM 33 A
Thermal Characteristics Characteristic Symbol Value Unit
Power Dissipation (Note 5) PD 1.67 W Power Dissipation (Note 6) PD 556 mW Thermal Resistance Junction to Ambient (Note 5) RJA 60 C/W Thermal Resistance Junction to Ambient (Note 6) RJA 180 C/W Thermal Resistance Junction to Soldering (Note 7) RJS 10 C/W Operating Temperature Range TJ -40 to +125 C Storage Temperature Range TSTG -40 to +150 C
Characteristic Symbol Min Typ Max Unit Test Condition
Reverse Breakdown Voltage (Note 8) V(BR)R 30 V IR = 1.0mA 0.310 IF = 1.0A Forward Voltage VF V 0.375 0.420 IF = 2.0A 0.260 V Leakage Current (Note 8) R = 5V, TA = +25C IR mA 1.0 VR = 30V, TA = +25C Total Capacitance CT 76 pF VR = 10V, f = 1.0MHz Notes: 5. Part mounted on 2"x2" GETEK board with 1"x1" copper pad, 25% anode, 75% cathode. TA = +25°C. 6. Part mounted on FR-4 board with recommended pad layout, which can be found on our website at http://www.diodes.com/package-outlines.html. 7. Theoretical RJS calculated from the top center of the die straight down to the PCB/cathode tab solder junction. 8. Short duration pulse test used to minimize self-heating effect. DFLS230L 2 of 5 July 2022 Document number: DS30515 Rev. 7 - 2
www.diodes.com
© 2022 Copyright Diodes Incorporated. All Rights Reserved.
