Datasheet DFLS230 (Diodes)
| Manufacturer | Diodes |
| Description | Schottky |
| Pages / Page | 5 / 1 — DFLS230. 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER. PowerDI123. … |
| File Format / Size | PDF / 688 Kb |
DFLS230. 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER. PowerDI123. Product Summary. Features and Benefits. RRM (V). IO (A). VF Max
DFLS230 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER PowerDI123 Product Summary Features and Benefits V RRM (V) IO (A) VF Max (V) IR Max (mA)
Guard Ring Die Construction for Transient Protection 30 2 0.49 1.0 Low Power Loss, High Efficiency Patented Interlocking Clip Design for High Surge Current Capacity Low Forward Voltage Drop
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) Halogen and Antimony Free. “Green” Device (Note 3) An Automotive-Compliant Part is Available Under Separate Datasheet (DFLS230Q) Description and Applications Mechanical Data
This Schottky Barrier Rectifier is ideally suited for use as: Package: PowerDI® 123 Polarity protection diodes Package Material—Molded Plastic, UL Flammability Rating 94V-0 Recirculating diodes Moisture Sensitivity: Level 1 per J-STD-020 Switching diodes Terminal Connections: Cathode Band Terminals: Finish—Matte Tin Annealed over Copper Leadframe. Solderable per MIL-STD-202, Method 208 Weight: 0.01 grams (Approximately) Power DI123 Top View
Ordering Information
(Note 4)
Packing Part Number Package Qty. Carrier
DFLS230-7 PowerDI123 3000 Tape & Reel Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/.
Marking Information
F01A = Product Type Marking Code YM = Date Code Marking F01A YM Y = Year (ex: J = 2022) M = Month (ex: 9 = September) Date Code Key
Year 2004 …. 2022 2023 2024 2025 2026 2027 2028 2029 2030 2031 Code
R …. J K L M N O P R S T
Month Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec Code
1 2 3 4 5 6 7 8 9 O N D PowerDI is a registered trademark of Diodes Incorporated. DFLS230 1 of 5 August 2022 Document number: DS30518 Rev. 4 - 2
www.diodes.com
© 2022 Copyright Diodes Incorporated. All Rights Reserved.
