Datasheet DFLS230LH (Diodes) - 2
| Manufacturer | Diodes |
| Description | Schottky |
| Pages / Page | 5 / 2 — DFLS230LH. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal … |
| File Format / Size | PDF / 451 Kb |
DFLS230LH. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics. Typ. Max. Electrical Characteristics. Min
DFLS230LH Maximum Ratings
(@TA = +25°C, unless otherwise specified.) Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Characteristic Symbol Value Unit
Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM 30 V DC Blocking Voltage VR RMS Reverse Voltage VR(RMS) 21 V Average Forward Current IF(AV) 2.0 A Non-Repetitive Peak Forward Surge Current 8.3ms I Single Half Sine-Wave Superimposed on Rated Load FSM 75 A
Thermal Characteristics Characteristic Symbol Typ Max Unit
Thermal Resistance Junction to Soldering Point (Note 5) RθJS — 6 °C/W Operating Temperature Range TJ -65 to +150 °C Storage Temperature Range TSTG -65 to +150 °C
Characteristic Symbol Min Typ Max Unit Test Condition
Reverse Breakdown Voltage (Note 6) V(BR)R 30 — — V IR = 200µA — — 0.45 I Forward Voltage F = 2A, TJ = +25°C VF — V — 0.375 IF = 2A, TJ = +125°C — — 0.200 V Leakage Current (Note 6) R = 30V, TJ = +25°C IR — mA 6 15 VR = 30V, TJ = +100°C Total Capacitance CT — 85 — pF VR = 10V, f = 1.0MHz Notes: 5. Theoretical RθJS calculated from the top center of the die straight down to the PCB/cathode tab solder junction. 6. Short duration pulse test used to minimize self-heating effect. DFLS230LH 2 of 5 August 2022 Document number: DS30583 Rev. 6 - 2
www.diodes.com
© 2022 Copyright Diodes Incorporated. All Rights Reserved.
