Datasheet RTDW (Bourns)
ManufacturerBourns
DescriptionRiedon Precision Wirewound Temperature Sensors
Pages / Page3 / 1 — Features. Additional Information. RTDW Series – Riedon™ Precision …
File Format / SizePDF / 645 Kb
Features. Additional Information. RTDW Series – Riedon™ Precision Wirewound Temperature Sensors by Bourns
Datasheet RTDW Bourns
Features Additional Information
n Formerly a Riedon™ product Click these links for more information: n Resistance tolerances to ±1 % n TCR to ±6000 PPM/°C n Flame & moisture resistant protective encapsulation PRODUCT TECHNICAL INVENTORY SAMPLES CONTACT LIBRARY n All welded construction n RoHS compliant*
RTDW Series – Riedon™ Precision Wirewound Temperature Sensors by Bourns Electrical Characteristics Specification Value
Standard Resistance Values 100 Ω, 500 Ω, 1 KΩ (referenced at 25 °C, others on request)1 Temperature Range 0 °C to +100 °C Recommended Measurement Current
100 Ω
- 1 mA to 7 mA |
500 Ω
- 0.7 mA to 3 mA |
1 KΩ
- 0.1 mA to 1 mA Response Time (approximate) 100 °C / 25 °C, still air, 50 %, 90 % t0.5 = 40 seconds t0.9 = 100 seconds Stability < 100 PPM/°C / year Terminations 100 % matte tin plating over copper Processing Meets the soldering requirements of MIL-STD-202, Method 208 Operating Conditions RTDW series temperature sensors may not be used in unprotected moist environments or in aggressive atmospheres. User should verify suitablility on a case by case basis. 1 Other resistance value may be available - please contact Bourns.
Product Dimensions RTDW12 RTDW22 RTDW32
Diameter “D” 3.2 ± 0.13 Diameter “D” 6.4 ± 0.13 (.125 ± .005) (.250 ± .005) Length “L” 6.6 ± 0.64 Length “L” 9.5 ± 0.64 (.260 ± .025) (.375 ± .025) Width “W” 3.6 ± 0.25 (.140 ± .010) Lead Diameter3 “d”
0.5
0.6 Lead Diameter3 “d”
0.8
0.6
(.020)
(.025)
(.032)
(.025) Height “H” 6.4 ± 0.64 L (.250 ± .025)W L W D (DIA.) L Length “L” 6.9 ± 0.25 D (DIA.) D (DIA.) L L D (DIA.) L d (DIA.) (.270 ± .010) d (DIA.) d (DIA.) d (DIA.) H H Lead Diameter “d” 0.8 (.032) 2 Other sizes available, please contact Bourns for Lead Spacing “A” 3.2 (.125) additional information. 3 Where more than one lead diameter is listed / L W the
bold
value is Standard. D (DIA.) L D (DIA.) L Lead length = 24.5 mm (1-inch) min. d (DIA.) d (DIA.) *RoHS Directive 2015/863, Mar 31, 2015 and Annex. d (DIA.) d (DIA.) H Specifications are subject to change without notice. A A DIMENSIONS: MM Users should verify actual device performance in their (INCHES) specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www. bourns.com/docs/legal/disclaimer.pdf. “Bourns” is a registered trademark of Bourns, Inc. in the United States and other countries. In April 2023, BE Services Company, Inc., a subsidiary of Bourns, Inc., purchased certain assets of Riedon, d (DIA.) Inc., including its logo and trademarks and the right to
CALIFORNIA WARNING:
Can expose you continue to manufacture former Riedon™ products. to lead, a carcinogen and reproductive A “Riedon Logo” is a registered trademark of BE Services toxicant. Company, Inc., in the United States. See www.P65Warnings.ca.gov “Riedon” is a trademark of BE Services Company, Inc.
