Datasheet SN74LVC1G16 (Texas Instruments) - 3
ManufacturerTexas Instruments
DescriptionOne-channel 1.65V-to-5.5V inverter with open-drain outputs and Schmitt-trigger inputs
Pages / Page30 / 3 — SN74LVC1G16. www.ti.com. 4 Pin Configuration and Functions. Figure 4-1. …
SN74LVC1G16. www.ti.com. 4 Pin Configuration and Functions. Figure 4-1. SN74LVC1G16 DBV Package, 5-Pin
SN74LVC1G16 www.ti.com 4 Pin Configuration and Functions Figure 4-1 SN74LVC1G16 DBV Package, 5-Pin
link to page 3
SCLSA29B – OCTOBER 2024 – REVISED MAY 2025
NC 1 5 VCC NC 1 5 VCC A 2 A 2 GND 3 4 Y GND 3 4 Y Not to scale Not to scale
Figure 4-1. SN74LVC1G16 DBV Package, 5-Pin Figure 4-2. SN74LVC1G16 DCK Package, 5-Pin SOT-23 (Top View) SOT-SC70 (Top View) Table 4-1. Pin Functions PIN TYPE
(1)
DESCRIPTION NAME NO.
NC 1 — No Connect, Leave floating or connect to ground A 2 Input Input A GND 3 — Ground Y 4 Output Output Y VCC 5 — Positive Supply (1) I = input, O = output, I/O = input or output, G = ground, P = power. Copyright © 2025 Texas Instruments Incorporated Submit Document Feedback 3 Product Folder Links: SN74LVC1G16 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configuration and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 Recommended Operating Conditions 5.4 Thermal Information 5.5 Electrical Characteristics 5.6 Switching Characteristics 5.7 Typical Characteristics 6 Parameter Measurement Information 7 Overview 8 Functional Block Diagram 9 Detailed Description 9.1 Feature Description 9.1.1 Open-Drain CMOS Outputs 9.1.2 CMOS Schmitt-Trigger Inputs 9.1.3 Clamp Diode Structure 10 Application and Implementation 10.1 Application Information 10.2 Typical Application 10.2.1 Design Requirements 10.2.1.1 Power Considerations 10.2.1.2 Input Considerations 10.2.1.3 Output Considerations 10.2.2 Detailed Design Procedure 10.3 Application Curves 10.4 Power Supply Recommendations 10.5 Layout 10.5.1 Layout Guidelines 10.5.2 Layout Example 11 Device and Documentation Support 11.1 Documentation Support 11.1.1 Related Documentation 11.2 Receiving Notification of Documentation Updates 11.3 Support Resources 11.4 Trademarks 11.5 Electrostatic Discharge Caution 11.6 Glossary 12 Revision History 13 Mechanical, Packaging, and Orderable Information
