Datasheet SN74LVC1G16 (Texas Instruments) - 8
ManufacturerTexas Instruments
DescriptionOne-channel 1.65V-to-5.5V inverter with open-drain outputs and Schmitt-trigger inputs
Pages / Page30 / 8 — SN74LVC1G16. www.ti.com. 7 Overview. 8 Functional Block Diagram
SN74LVC1G16 www.ti.com 7 Overview 8 Functional Block Diagram
SN74LVC1G16
SCLSA29B – OCTOBER 2024 – REVISED MAY 2025
The SN74LVC1G16 device contains one open-drain inverter with a maximum sink current of 32 mA. This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs when the device is powered down. This inhibits current backflow into the device which prevents damage to the device.
A Y 8 Submit Document Feedback Copyright © 2025 Texas Instruments Incorporated Product Folder Links: SN74LVC1G16 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configuration and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 Recommended Operating Conditions 5.4 Thermal Information 5.5 Electrical Characteristics 5.6 Switching Characteristics 5.7 Typical Characteristics 6 Parameter Measurement Information 7 Overview 8 Functional Block Diagram 9 Detailed Description 9.1 Feature Description 9.1.1 Open-Drain CMOS Outputs 9.1.2 CMOS Schmitt-Trigger Inputs 9.1.3 Clamp Diode Structure 10 Application and Implementation 10.1 Application Information 10.2 Typical Application 10.2.1 Design Requirements 10.2.1.1 Power Considerations 10.2.1.2 Input Considerations 10.2.1.3 Output Considerations 10.2.2 Detailed Design Procedure 10.3 Application Curves 10.4 Power Supply Recommendations 10.5 Layout 10.5.1 Layout Guidelines 10.5.2 Layout Example 11 Device and Documentation Support 11.1 Documentation Support 11.1.1 Related Documentation 11.2 Receiving Notification of Documentation Updates 11.3 Support Resources 11.4 Trademarks 11.5 Electrostatic Discharge Caution 11.6 Glossary 12 Revision History 13 Mechanical, Packaging, and Orderable Information
