Datasheet SN74HCS05 (Texas Instruments) - 6
| Description | 6-ch, 2-V to 6-V inverters with Schmitt-Trigger inputs and open-drain outputs |
| Pages / Page | 24 / 6 — SN74HCS05. www.ti.com. 6.8 Typical Characteristics. Figure 6-1. Output … |
| File Format / Size | PDF / 1.0 Mb |
SN74HCS05. www.ti.com. 6.8 Typical Characteristics. Figure 6-1. Output driver resistance in Low state
SN74HCS05
SCLS797A – JUNE 2020 – REVISED OCTOBER 2020
www.ti.com 6.8 Typical Characteristics
TA = 25°C 46 0.2 VCC = 2 V VCC = 2 V 44 V 0.18 CC = 3.3 V 42 VCC = 4.5 V ) 0.16 VCC = 2.5 V ) VCC = 6 V : 40 t (mA 0.14 VCC = 3.3 V ce ( n 38 rre 0.12 u sistan 36 C 0.1 ly p t Re 34 p 0.08 u tp Su 32 ± 0.06 Ou CIC 30 0.04 28 0.02 26 0 0 2.5 5 7.5 10 12.5 15 17.5 20 22.5 25 0 0.5 1 1.5 2 2.5 3 3.5 Output Sink Current (mA) VI ± Input Voltage (V)
Figure 6-1. Output driver resistance in Low state Figure 6-2. Typical supply current versus input voltage across common supply values (2 V to 3.3 V)
0.65 0.6 VCC = 4.5 V 0.55 ) VCC = 5 V 0.5 V t (mA 0.45 CC = 6 V n 0.4 rre u C 0.35 ly 0.3 p p 0.25 Su ± 0.2 CIC 0.15 0.1 0.05 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 VI ± Input Voltage (V)
Figure 6-3. Typical supply current versus input voltage across common supply values (4.5 V to 6 V)
6 Submit Document Feedback Copyright © 2020 Texas Instruments Incorporated Product Folder Links: SN74HCS05 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions Pin Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Switching Characteristics 6.7 Operating Characteristics 6.8 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Open-Drain CMOS Outputs 8.3.2 CMOS Schmitt-Trigger Inputs 8.3.3 Clamp Diode Structure 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.1.1 Power Considerations 9.2.1.2 Input Considerations 9.2.1.3 Output Considerations 9.2.2 Detailed Design Procedure 9.2.3 Application Curves 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Support Resources 12.4 Trademarks 12.5 Electrostatic Discharge Caution 12.6 Glossary 13 Mechanical, Packaging, and Orderable Information
