Datasheet TCST1103 (Vishay)
ManufacturerVishay
DescriptionTransmissive Optical Sensor with Phototransistor Output
Pages / Page7 / 1 — TCST1103, TCST1202, TCST1300. Transmissive Optical Sensor with …
File Format / SizePDF / 109 Kb
TCST1103, TCST1202, TCST1300. Transmissive Optical Sensor with Phototransistor Output. FEATURES. DESCRIPTION. APPLICATIONS
Datasheet TCST1103 Vishay
Transmissive Optical Sensor with Phototransistor Output FEATURES
• Package type: leaded • Detector type: phototransistor • Dimensions (L x W x H in mm): 11.9 x 6.3 x 10.8 • Gap (in mm): 3.1 19180_5 • Typical output current under test: IC = 4 mA (TCST1103) Top view • Typical output current under test: IC = 2 mA (TCST1202) + D • Typical output current under test: IC = 0.5 mA (TCST1300) • Daylight blocking filter E + • Emitter wavelength: 950 nm 0.3" • Lead (Pb)-free soldering released 19180_3 7.6 mm • Compliant to RoHS Directive 2002/95/EC and in
DESCRIPTION
accordance to WEEE 2002/96/EC The TCST1103, TCST1202, and TCST1300 are transmissive
sensors that include an infrared emitter and phototransistor, • Optical switch located face-to-face on the optical axes in a leaded package which blocks visible light. These part numbers include • Photo interrupter options for aperture width. • Counter • Encoder
PRODUCT SUMMARY TYPICAL OUTPUT CURRENT DAYLIGHT PART NUMBER GAP WIDTH APERTURE WIDTH (mm) (mm) UNDER TEST (1) BLOCKING FILTER (mA) INTEGRATED
TCST1103 3.1 1 4 Yes TCST1202 3.1 0.5 2 Yes TCST1300 3.1 0.25 0.5 Yes
Note
• Conditions like in table basic characteristics/coupler
ORDERING INFORMATION ORDERING CODE PACKAGING VOLUME (1) REMARKS
TCST1103 Tube MOQ: 1020 pcs, 85 pcs/tube Without mounting flange TCST1202 Tube MOQ: 1020 pcs, 85 pcs/tube Without mounting flange TCST1300 Tube MOQ: 1020 pcs, 85 pcs/tube Without mounting flange
Note
• MOQ: minimum order quantity
ABSOLUTE MAXIMUM RATINGS
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL VALUE UNIT COUPLER
Total power dissipation Tamb ≤ 25 °C Ptot 250 mW Ambient temperature range Tamb - 55 to + 85 °C Storage temperature range Tstg - 55 to + 100 °C Soldering temperature Distance to package: 2 mm; t ≤ 5 s Tsd 260 °C Rev. 2.0, 24-Aug-11
1
Document Number: 83764 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
