Datasheet TCRT5000 (Vishay)
ManufacturerVishay
DescriptionReflective Optical Sensor With Transistor Output
Pages / Page7 / 1 — TCRT5000, TCRT5000L. Reflective Optical Sensor with Transistor Output. …
File Format / SizePDF / 177 Kb
TCRT5000, TCRT5000L. Reflective Optical Sensor with Transistor Output. FEATURES. DESCRIPTION. APPLICATIONS. PRODUCT SUMMARY
Datasheet TCRT5000 Vishay
TCRT5000, TCRT5000L
Vishay Semiconductors
Reflective Optical Sensor with Transistor Output FEATURES
• Package type: leaded • Detector type: phototransistor • Dimensions (L x W x H in mm): 10.2 x 5.8 x 7 • Peak operating distance: 2.5 mm • Operating range within > 20 % relative collector 19156_2 current: 0.2 mm to 15 mm • Typical output current under test: IC = 1 mA C A • Daylight blocking filter • Emitter wavelength: 950 nm • Lead (Pb)-free soldering released E C • Compliant to RoHS directive 2002/95/EC and in Top view accordance to WEEE 2002/96/EC 19156_1
DESCRIPTION APPLICATIONS
The TCRT5000 and TCRT5000L are reflective sensors • Position sensor for shaft encoder which include an infrared emitter and phototransistor in a • Detection of reflective material such as paper, IBM cards, leaded package which blocks visible light. The package magnetic tapes etc. includes two mounting clips. TCRT5000L is the long lead • Limit switch for mechanical motions in VCR version. • General purpose - wherever the space is limited
PRODUCT SUMMARY DISTANCE FOR DISTANCE RANGE FOR TYPICAL OUTPUT DAYLIGHT PART NUMBER MAXIMUM CTRrel (1) RELATIVE Iout > 20 % CURRENT UNDER TEST (2) BLOCKING FILTER (mm) (mm) (mA) INTEGRATED
TCRT5000 2.5 0.2 to 15 1 Yes TCRT5000L 2.5 0.2 to 15 1 Yes
Notes
(1) CTR: current transfere ratio, Iout/Iin (2) Conditions like in table basic charactristics/sensors
ORDERING INFORMATION ORDERING CODE PACKAGING VOLUME (1) REMARKS
TCRT5000 Tube MOQ: 4500 pcs, 50 pcs/tube 3.5 mm lead length TCRT5000L Tube MOQ: 2400 pcs, 48 pcs/tube 15 mm lead length
Note
(1) MOQ: minimum order quantity
ABSOLUTE MAXIMUM RATINGS (1) PARAMETER TEST CONDITION SYMBOL VALUE UNIT INPUT (EMITTER)
Reverse voltage VR 5 V Forward current IF 60 mA Forward surge current tp ≤ 10 µs IFSM 3 A Power dissipation Tamb ≤ 25 °C PV 100 mW Junction temperature Tj 100 °C Document Number: 83760 For technical questions, contact: sensorstechsupport@vishay.com www.vishay.com Rev. 1.7, 17-Aug-09 1
