Datasheet TCRT5000 (Vishay) - 2
ManufacturerVishay
DescriptionReflective Optical Sensor With Transistor Output
Pages / Page7 / 2 — TCRT5000, TCRT5000L. ABSOLUTE MAXIMUM RATINGS (1). PARAMETER. TEST …
File Format / SizePDF / 177 Kb
TCRT5000, TCRT5000L. ABSOLUTE MAXIMUM RATINGS (1). PARAMETER. TEST CONDITION. SYMBOL. VALUE. UNIT. OUTPUT (DETECTOR). SENSOR. Note
TCRT5000, TCRT5000L ABSOLUTE MAXIMUM RATINGS (1) PARAMETER TEST CONDITION SYMBOL VALUE UNIT OUTPUT (DETECTOR) SENSOR Note
TCRT5000, TCRT5000L
Vishay Semiconductors Reflective Optical Sensor with Transistor Output
Collector emitter voltage VCEO 70 V Emitter collector voltage VECO 5 V Collector current IC 100 mA Power dissipation Tamb ≤ 55 °C PV 100 mW Junction temperature Tj 100 °C
SENSOR
Total power dissipation Tamb ≤ 25 °C Ptot 200 mW Ambient temperature range Tamb - 25 to + 85 °C Storage temperature range Tstg - 25 to + 100 °C Soldering temperature 2 mm from case, t ≤ 10 s Tsd 260 °C
Note
(1) Tamb = 25 °C, unless otherwise specified
300 ) W Coupled device (m 200 Phototransistor er Dissipation w 100 IR - diode P - Po 0 0 25 50 75 100 95 11071 Tamb - Ambient Temperature (°C) Fig. 1 - Power Dissipation Limit vs. Ambient Temperature
BASIC CHARACTERISTICS (1) PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT INPUT (EMITTER)
Forward voltage IF = 60 mA VF 1.25 1.5 V Junction capacitance VR = 0 V, f = 1 MHz Cj 17 pF Radiant intensity IF = 60 mA, tp = 20 ms Ie 21 mW/sr Peak wavelength IF = 100 mA λP 940 nm Virtual source diameter Method: 63 % encircled energy d 2.1 mm
OUTPUT (DETECTOR)
Collector emitter voltage IC = 1 mA VCEO 70 V Emitter collector voltage Ie = 100 µA VECO 7 V Collector dark current VCE = 20 V, IF = 0 A, E = 0 lx ICEO 10 200 nA
SENSOR
V Collector current CE = 5 V, IF = 10 mA, I D = 12 mm C (2) (3) 0.5 1 2.1 mA Collector emitter saturation IF = 10 mA, IC = 0.1 mA, V voltage D = 12 mm CEsat (2) (3) 0.4 V
Note
(1) Tamb = 25 °C, unless otherwise specified (2) See figure 3 (3) Test surface: mirror (Mfr. Spindler a. Hoyer, Part No. 340005) www.vishay.com For technical questions, contact: sensorstechsupport@vishay.com Document Number: 83760 2 Rev. 1.7, 17-Aug-09
