Datasheet E2B (Omron) - 5
ManufacturerOmron
DescriptionCylindrical Proximity Sensor
Pages / Page22 / 5 — E2B. Model Number Legend. E2B-. 2 3 4 5 6. 8 9. Example: E2B-M12LS04-M1-B1
File Format / SizePDF / 6.9 Mb
E2B Model Number Legend E2B- 2 3 4 5 6 8 9 Example: E2B-M12LS04-M1-B1
E2B
1 2 3 4 5 6 7 8 9 10 Example: E2B-M12LS04-M1-B1 M12, Brass, Long body, Shielded, Sn = 4 mm, M12 connector, PNP, NO E2B-S08KN02-WP-C2 5M M8, stainless steel, Short body, Unshielded, Sn = 2 mm, Pre-wired PVC cable, NPN, NC, Cable length = 5 m 1. Basic name 7. Kind of connection
E2B WZ: Pre-wired, PVC, dia 4 mm Conductor cross section : 0.3 mm2
2. Housing shape and material
Insulator diameter : 1.3 mm M: Cylindrical, metric threaded, brass (See note 1.) S: Cylindrical, metric threaded, stainless steel WP: Pre-wired, PVC, dia 4 mm Conductor cross section : 0.141 mm2
3. Housing size
Insulator diameter : 0.85 mm 08: 8 mm M1: M12 connector 12: 12 mm MC: M8 connector (3 pin) 18: 18 mm (See note 2.) 30: 30 mm
8. Power source and output 4. Barrel length
B: PNP K: Short body C: NPN L: Long body
9. Operation mode 5. Shield
1: NO (Normally open) S: Shielded 2: NC (Normally closed) N: Unshielded
10.Cable length 6. Sensing distance
Blank: Connector type Numeral: Sensing distance: Numeral: Cable length (2M and 5M are available.) 01 = 1.5 mm, 02 = 2 mm, 04 = 4 mm, 05 = 5 mm, 08 = 8 mm, 10 = 10 mm, 15 = 15 mm, 16 = 16 mm, 20 = 20 mm, 30 = 30 mm Note: 1. Only M12, M18, M30 type. 2. "WP", "M1" and "MC" are listed products of UL.
5
