Catalog E2B (Omron) - 4
ManufacturerOmron
DescriptionCylindrical Proximity Sensor
Pages / Page28 / 4 — Al around Visible. Pay only for what you need. IP67. E2B. E2A
File Format / SizePDF / 7.9 Mb
Al around Visible Pay only for what you need IP67 E2B E2A
E2B
4 Time and cost savings For standard conditions you can easily select E2B sensors because they have an easy-to-read code without complex codification. They also have a bright circular LED indicator, so you can quickly determine their operating status. These two features reduce the effort in machine maintenance, so you wil save time and money. 360-degree indication
Al around Visible
Easy visibility for 360° even in dark locations so you can mount the sensor in any direction. The ideal solution for standard industrial environments
Most industrial applications are conducted in a standard environment, in a normal temperature range, without extremes such as high oil- or water-pressure, or strong electromagnetic fields, or constant high mechanical stresses. This makes E2B the ideal solution for the vast majority of applications. It’s perfectly reliable for normal conditions. What’s more, you get just what you need without paying for unnecessary extreme robustness. For example, in the machine-tool industry, E2B sensors are ideal for detecting tool positions or line encoders. For packaging machines they can be used for detecting the positions of welded or pressed elements.
IP67
We have performed not only a specified test for rating the degree of protection (IP67) for catalogs, but also tests with oil mist Oil-mist environment resistant! which appears onsite. Simulation tests has been performed with attachment of high concentration of oil mist.
E2B E2A
Feature Superior price Superior robustness Oil/water resistance Good Good IP IP67 IP69K Temperature -25 to 70°C -40 to 70°C Other Lineup of 2-wire models, and AC types are available. NO+NC. Customization
