https://www.rlocman.ru/i/File/2025/11/13/SN74LVC1G74.pdf
/var/www/html/i/File/2025/11/13/SN74LVC1G74.pdf
db_file_exists = 1 SN74LVC1G74. www.ti.com. 6 Specifications 6.1 Absolute Maximum Ratings. MIN. MAX UNIT. 6.2 ESD Ratings. PARAMETER. DEFINITION. VALUE - Datasheet SN74LVC1G74 Texas Instruments
Datasheet SN74LVC1G74 (Texas Instruments) - 5
ManufacturerTexas Instruments
DescriptionSingle Positive-Edge-Triggered D-Type Flip-Flop With Clear and Preset
Pages / Page31 / 5 — SN74LVC1G74. www.ti.com. 6 Specifications 6.1 Absolute Maximum Ratings. …
SN74LVC1G74 www.ti.com 6 Specifications 6.1 Absolute Maximum Ratings MIN MAX UNIT 6.2 ESD Ratings PARAMETER DEFINITION VALUE
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 6 link to page 6 link to page 6 link to page 5 link to page 5
SCES794G – OCTOBER 2009 – REVISED SEPTEMBER 2021
over operating free-air temperature range (unless otherwise noted)(1)
MIN MAX UNIT
VCC Supply voltage range –0.5 6.5 V VI Input voltage range(2) –0.5 6.5 V VO Voltage range applied to any output in the high-impedance or power-off state(2) –0.5 6.5 V VO Voltage range applied to any output in the high or low state(2) (3) –0.5 VCC + 0.5 V IIK Input clamp current VI < 0 –50 mA IOK Output clamp current VO < 0 –50 mA IO Continuous output current ±50 mA Continuous current through VCC or GND ±100 mA Tstg Storage temperature range –65 150 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. (2) The input negative-voltage and output voltage ratings may be exceeded if the input and output clamp-current ratings are observed. (3) The value of VCC is provided in the Recommended Operating Conditions table.
6.2 ESD Ratings PARAMETER DEFINITION VALUE UNIT
Human body model (HBM), per ANSI/ESDA/JEDEC JS-001, all pins(1) 2000 V V(ESD) Electrostatic discharge Charged device model (CDM), per JEDEC specification JESD22-C101, all 1000 pins(2) (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Copyright © 2021 Texas Instruments Incorporated Submit Document Feedback 5 Product Folder Links: SN74LVC1G74 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Timing Requirements 6.7 Switching Characteristics 6.8 Operating Characteristics 6.9 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Power Button Circuit 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curves 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Receiving Notification of Documentation Updates 12.2 Support Resources 12.3 Trademarks 12.4 Electrostatic Discharge Caution 12.5 Glossary 13 Mechanical, Packaging, and Orderable Information
