Datasheet IKCM15F60GD (Infineon) - 3
ManufacturerInfineon
DescriptionControl Integrated POwer System (CIPOS ) Dual In-Line Intelligent Power Module 3Φ -bridge 600V / 15A
Pages / Page17 / 3 — Control. Integrated. POwer. System. (CIPOS™). IKCM15L60GD. CIPOS™. …
Control. Integrated. POwer. System. (CIPOS™). IKCM15L60GD. CIPOS™. Control. Integrated. POwer. System. Dual. In-Line. Intelligent. Power. Module. 3Φ
Control Integrated POwer System (CIPOS™) IKCM15L60GD CIPOS™ Control Integrated POwer System Dual In-Line Intelligent Power Module 3Φ
Control Integrated POwer System (CIPOS™) IKCM15L60GD CIPOS™ Control Integrated POwer System Dual In-Line Intelligent Power Module 3Φ -bridge 600V / 15A Features Description Fully isolated Dual In-Line molded module The CIPOS™ module family offers the chance for TRENCHSTOP™ IGBTs integrating various power and control components Rugged SOI gate driver technology with stability to increase reliability, optimize PCB size and system against transient and negative voltage costs. Allowable negative VS potential up to -11V for It is designed to control three phase AC motors and signal transmission at VBS=15V permanent magnet motors in variable speed drives Integrated bootstrap functionality for applications like an air conditioning, a Over current shutdown refrigerator and a washing machine. The package concept is specially adapted to power applications, Temperature monitor which need good thermal conduction and electrical Under-voltage lockout at all channels isolation, but also EMI-save control and overload Low side emitter pins accessible for all phase protection. current monitoring (open emitter) Cross-conduction prevention TRENCHSTOP™ IGBTs and anti parallel diodes are All of 6 switches turn off during protection combined with an optimized SOI gate driver for Lead-free terminal plating; RoHS compliant excellent electrical performance. Very low thermal resistance due to DCB System Configuration Target Applications 3 half bridges with TRENCHSTOP™ IGBTs and Home appliances anti parallel diodes Low power motor drives 3Φ SOI gate driver Thermistor Pin-to-heatsink clearance distance typ. 1.6mm Datasheet 3 of 17 V 2.3 2017-09-06 Document Outline Table of contents CIPOS™ Control Integrated POwer System Features Target Applications Description System Configuration Pin Configuration Internal Electrical Schematic Pin Assignment Pin Description HIN(U, V, W) and LIN(U, V, W) (Low side and high side control pins, Pin 7 - 12) VFO (Fault-output and NTC, Pin 14) ITRIP (Over current detection function, Pin 15) VDD, VSS (Low side control supply and reference, Pin 13, 16) VB(U, V, W) and VS(U, V, W) (High side supplies, Pin 1 - 6) NW, NV, NU (Low side emitter, Pin 17 - 19) W, V, U (High side emitter and low side collector, Pin 20 - 22) P (Positive bus input voltage, Pin 23) Absolute Maximum Ratings Module Section Inverter Section Control Section Recommended Operation Conditions Static Parameters Dynamic Parameters Bootstrap Parameters Thermistor Mechanical Characteristics and Ratings Circuit of a Typical Application Switching Times Definition Electrical characteristic Package Outline Revision history
