Datasheet HWZT (Abracon) - 2
| Manufacturer | Abracon |
| Description | Ceramic resonator 12 MHz t/h |
| Pages / Page | 3 / 2 — LEADED CERAMIC RESONATOR. RoHS/RoHS II Compliant. Siz e Varies. … |
| File Format / Size | PDF / 2.6 Mb |
LEADED CERAMIC RESONATOR. RoHS/RoHS II Compliant. Siz e Varies. FEATURES:. APPLICATIONS:. STANDARD SPECIFICATIONS:. Parameters
HWZT-MD
Pb in ceramic, exemption (7c-I)
Siz e Varies
FEATURES: APPLICATIONS:
• Low resonant impedance • Clock oscillation for microcontrollers • Small size, Light weight. • Telephones • Low cost timing solution • Household electric appliances
STANDARD SPECIFICATIONS: Parameters Minimum Typical Maximum Units Notes
2.00 6.00 Frequency Range MHz 12.51 60.00 80 2.00 MHz ~ 2.99 MHz Resonant Impedance (Ro) 30 Ω 3.00 MHz ~ 6.00 MHz 30 12.51 MHz ~ 60.00 MHz 24 30 36 2.00 MHz ~ 6.00 MHz Standard Load Capacitance for 24 30 36 12.51 MHz ~ 20.00 MHz test circuit (C1=C2) pF 12 15 18 20.01 MHz ~ 25.99 MHz 4 5 6 26.00 MHz ~ 60.00 MHz Frequency Tolerance -0.5 +0.5 % Frequency Stability -0.3 +0.3 % -25ºC to +85ºC Withstanding Voltage 50 Vdc DC , 1 min D.C. Voltage 6 Vdc Rating Voltage A.C. Voltage 15 Vp-p. Insulation Resistance 100 MΩ 10Vdc, 1min Operation Temperature -25 +85 ºC Storage Temperature -55 +85 ºC Aging Rate (Fosc) -0.3 0.3 % From initial value
TEST CONDITION AND TEST CIRCUIT: OPTIONS & PART IDENTIFICATION:
EOLHWZT - MD - X: Ceramic Resonator
Frequency Packaging
Blank: Bulk Frequency in MHz A: AMMO package* *AMMO package Parts shall be measured under a condition (Temp.: lead length 13.5mm 20±15°C, Humidity: 65±20% R.H.) unless the standard condition (Temp: 25±2°C, Humidity: 65±5% R.H.) is regulated to measure Visit www.abracon.com for Terms & Conditions of Sale ABRACON IS
Revised: 05.07.13
ISO9001:2008 30332 Esperanza, Rancho Santa Margarita, California 92688 CER CE TIFIED R tel 949-546-8000 | fax 949-546-8001 | www.abracon.com Document Outline EOL-ECN #3520 HWZT-MD.pdf HWZT_MD.pdf
