LEADED CERAMIC RESONATOR HWZT-MD RoHS/RoHS II Compliant Pb in ceramic, exemption (7c-I) Siz e Varies | | | | | | | | | | | | | | | OUTLINE DRAWING:Freq. Range: 2.00 ~ 6.00MHz (Low Profil e)Bulk:AMMO:Freq. Range: 12.51 ~ 60.00MHzBulk: 10.0max 5.0max AMMO: ** H 0.5±0.1 5.0±1.0 0.25±0.1 5.0±0.30 H : 12.51 ~ 23.99MHz, 10.0m *:EIAJ MONTHLY CODE m max 24.00 ~ 31.99MHz, 7.5mm max Dimension: mm 32.00 ~ 60.00MHz, 6.5mm max Packaging:Bulk: 500pcs/plastic bag AMMO: 2000pcs/box Note: upon opening the original packaging, it is recommended that the product be used within 1 year. If the prod- uct will not be used within 1 year, it is recommended that the product be re-sealed in airtight packaging according to MSL 1 requirements to maintain solderability. CAUTION EOL (1) Do not apply excess mechanical stress to the component body or terminations. Do not attempt to re-form or bend the components as this will cause damage to the component. (2) This component is not hermetically sealed. Do not clean or wash the component. (3) Reflow Soldering: Do not use strong acidity flux, such as flux with chlorine content of greater than 0.2wt% during Reflow Soldering. (4) Do not expose the component to open flame. (5) This specification applies to the functionality of the component as a single unit. (6) Storage Conditions: If the product is to be stored for a period greater than 1 year after the Delivery Date, it is recommended that customers confirm the solderability and characteristics for the product prior to use. (7) This product is not recommended for use in the following applications: Automotive, Medical, Military, Safety, or any other high- reliabilit , y life dependant applications. ContactAbracon Corporation prior to using this product when in doubt. ATTENTION: Abracon Corporation’s products are COTS – Commercial-Off-The-Shelf products; suitable for Commercial, Industrial and, where designated, Automotive Applica- tions. Abracon’s products are not specifically designed for Military, Aviation, Aerospace, Life-dependant Medical applications or any application requiring high reliability where component failure could result in loss of life and/or property. For applications requiring high reliability and/or presenting an extreme operating environment, written consent and authorization from Abracon Corporation is required. Please contact Abracon Corporation for more information. Visit www.abracon.com for Terms & Conditions of Sale ABRACON IS Revised: 05.07.13 ISO9001:2008 30332 Esperanza, Rancho Santa Margarita, California 92688 CERTIFIED CER tel 949-546-8000 | fax 949-546-8001 | www.abracon.com Document Outline EOL-ECN #3520 HWZT-MD.pdf HWZT_MD.pdf
