Datasheet STM32F103x8, STM32F103xB (STMicroelectronics)
DescriptionMainstream Performance line, ARM Cortex-M3 MCU with 64 Kbytes Flash, 72 MHz CPU, motor control, USB and CAN
Pages / Page114 / 1 — STM32F103x8. STM32F103xB. Medium-density performance line Arm®-based …
Revision20
STM32F103x8. STM32F103xB. Medium-density performance line Arm®-based 32-bit MCU with
Datasheet STM32F103x8, STM32F103xB STMicroelectronics, Revision: 20
STM32F103x8
STM32F103xB
64 or 128 KB Flash, USB, CAN, 7 timers, 2 ADCs, 9 com. interfaces
Datasheet -production data Features
Includes ST state-of-the-art patented
technology
• Arm® 32-bit Cortex®-M3 CPU core
– 72 MHz maximum frequency, 1.25
DMIPS/MHz (Dhrystone 2.1) performance
at 0 wait state memory access
– Single-cycle multiplication and hardware
division VFQFPN36 6 × 6 mm BGA100 10 × 10 mm
UFBGA100 7 × 7 mm
BGA64 5 × 5 mm UFQFPN48 7 × 7 mm LQFP100 14 × 14 mm
LQFP64 10 × 10 mm
LQFP48 7 × 7 mm • Memories
– 64 or 128 Kbytes of Flash memory
– 20 Kbytes of SRAM • Debug mode:
– Serial wire debug (SWD) and JTAG
interfaces • Clock, reset and supply management
– 2.0 to 3.6 V application supply and I/Os
– POR, PDR, and programmable voltage
detector (PVD)
– 4 to 16 MHz crystal oscillator
– Internal 8 MHz factory-trimmed RC
– Internal 40 kHz RC
– PLL for CPU clock
– 32 kHz oscillator for RTC with calibration • Seven timers
– Three 16-bit timers, each with up to
4 IC/OC/PWM or pulse counter and
quadrature (incremental) encoder input
– 16-bit, motor control PWM timer with
dead-time generation and emergency stop
– Two watchdog timers (independent and
window)
– SysTick timer 24-bit downcounter • Low-power
– Sleep, Stop and Standby modes
– VBAT supply for RTC and backup registers
• 2x 12-bit, 1 µs A/D converters (up to 16
channels)
– Conversion range: 0 to 3.6 V
– Dual-sample and hold capability
– Temperature sensor • CRC calculation unit, 96-bit unique ID • DMA
– 7-channel DMA controller
– Peripherals supported: timers, ADC, SPIs,
I2Cs and USARTs
• Up to 80 fast I/O ports
– 26/37/51/80 I/Os, all mappable on 16
external interrupt vectors and almost all
5 V-tolerant July 2025
This is information on a product in full production. • Up to nine communication interfaces
– Up to two I2C interfaces (SMBus/PMBus®)
– Up to three USARTs (ISO 7816 interface,
LIN, IrDA capability, modem control)
– Up to two SPIs (18 Mbit/s)
– CAN interface (2.0B Active)
– USB 2.0 full-speed interface
• Packages are ECOPACK®
Table 1. Device summary
Reference Part number STM32F103x8 STM32F103C8, STM32F103R8
STM32F103V8, STM32F103T8 STM32F103xB STM32F103RB STM32F103VB,
STM32F103CB, STM32F103TB DS5319 Rev 20 1/114
www.st.com
