Datasheet MAT04 (Analog Devices) - 4
DescriptionMatched Monolithic Quad Transistor
Pages / Page12 / 4 — MAT04. ABSOLUTE MAXIMUM RATINGS1. DICE CHARACTERISTICS. Q1 COLLECTOR. Q1 …
File Format / SizePDF / 874 Kb
MAT04. ABSOLUTE MAXIMUM RATINGS1. DICE CHARACTERISTICS. Q1 COLLECTOR. Q1 BASE. Q1 EMITTER. SUBSTRATE. Q2 EMITTER. Q2 BASE. Q2 COLLECTOR
MAT04 ABSOLUTE MAXIMUM RATINGS1 DICE CHARACTERISTICS Q1 COLLECTOR Q1 BASE Q1 EMITTER SUBSTRATE Q2 EMITTER Q2 BASE Q2 COLLECTOR
Collector-Base Voltage (BV
CBO) . 40 V Collector-Emitter Voltage (BVCEO) . 40 V Collector-Collector Voltage (BV
1. Q1 COLLECTOR
CC) . 40 V Emitter-Emitter Voltage (BV
2. Q1 BASE
EE) . 40 V
3. Q1 EMITTER
Collector Current . 30 mA
4. SUBSTRATE
Emitter Current . 30 mA
5. Q2 EMITTER
Substrate (Pin-4 to Pin-11) Current . 30 mA
6. Q2 BASE
Operating Temperature Range
7. Q2 COLLECTOR 8. Q3 COLLECTOR
MAT04EY . –25°C to +85°C
9. Q3 BASE
MAT04FY, FP, FS . –40°C to +85°C
10. Q3 EMITTER
Storage Temperature
11. SUBSTRATE
Y Package . –65°C to +150°C
12. Q4 EMITTER
P Package . –65°C to +125°C
13. Q4 BASE 14. Q4 COLLECTOR
Lead Temperature (Soldering, 60 sec) . +300°C Die Size 0.060 × 0.060 Inch, 3600 Sq. mm
Package Type
2
JA JC Units
(1.52 × 1.52 mm, 2.31 sq. mm) 14-Lead Cerdip 108 16 °C/W 14-Lead Plastic DIP 83 39 °C/W 14-Lead SO 120 36 °C/W NOTES 1Absolute maximum ratings apply to both DICE and packaged parts, unless otherwise noted. 2␪JA is specified for worst case mounting conditions, i.e., ␪JA is specified for device in socket for cerdip and P-DIP packages; ␪JA is specified for device soldered to printed circuit board for SO package.
ORDERING GUIDE TA = 25
C Temperature Package Package Model VOS max Range Description Option
MAT04EY* 200 µV –25°C to +85°C Cerdip Q-14 MAT04FY* 400 µV –40°C to +85°C Cerdip Q-14 MAT04FP 400 µV –40°C to +85°C P-DIP-14 N-14 MAT04FS 400 µV –40°C to +85°C 14-Lead SO SO-14 NOTES *Not for new designs; obsolete April 2002.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection.
WARNING!
Although the MAT04 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD
ESD SENSITIVE DEVICE
precautions are recommended to avoid performance degradation or loss of functionality. –4– REV. D
