Datasheet THAT 300 (THAT Corporation) - 3
ManufacturerTHAT Corporation
DescriptionLow-Noise Matched Transistor Arrays
Pages / Page8 / 3 — SPECIFICATIONS1 (Cont’d). NPN Electrical Characteristics2 (cont’d). PNP …
File Format / SizePDF / 108 Kb
SPECIFICATIONS1 (Cont’d). NPN Electrical Characteristics2 (cont’d). PNP Electrical Characteristics2
SPECIFICATIONS1 (Cont’d) NPN Electrical Characteristics2 (cont’d) PNP Electrical Characteristics2
THAT 300 Series Transistor Array ICs Page 3 of 8 Document 600041 Rev 04
Parameter Symbol Conditions 300 / 340(Q1,Q2) 300A 300B Units Min Typ Max Min Typ Max Min Typ Max NPN Output Capacitance COB VCB = 10V, IE = 0mA, 100kHz — 3 — — 3 — — 3 — pF NPN Breakdown Voltage BVCEO IC = 10 μAdc, IB = 0 36 40 — 36 40 — 36 40 — V Input Capacitance CEBO I — C = 0 mA, VEB = 0 V 5 — — 5 — — 5 — pF
Parameter Symbol Conditions Min Typ Max Units PNP Current Gain hfe VCB = -10 V IC = -1 mA 50 75 — IC = -10 μA — 75 — PNP Current Gain Matching Δhfe VCB = -10 V, IC = -1 mA — 5 — % PNP Noise Voltage Density eN VCB = -10 V, IC = -1 mA, 1 kHz — 0.75 — nV√Hz PNP Gain-Bandwidth Product fT IC = -1 mA, VCB = -10 V — 325 — MHz PNP ΔVBE VOS IC = -1 mA — 0.5 3 mV 320: |VBE1-VBE2| ; |VBE3-VBE4| IC = -10 μA — 0.5 — mV 340: |VBE1-VBE2| PNP ΔIB IOS IC = -1 mA — 700 1800 nA 320: |IB1-IB2| ; |IB3-IB4| IC = -10 μA — 7 — nA 340: |IB1-IB2| PNP Collector-Base Leakage Current ICBO VCB = -25 V — –25 — pA PNP Bulk Resistance rBE VCB = 0 V, -10μA > IC> -10 mA — 2 — Ω PNP Base Spreading Resistance rbb VCB = -10 V, IC = -1 mA — 25 — Ω PNP Collector Saturation Voltage VCE(SAT) IC = -1 mA, IB = -100 μA — –0.05 — V PNP Output Capacitance COB VCB = -10 V, IE = 0 mA, 100 kHz — 3 — pF PNP Breakdown Voltage BVCEO IC = -10 μAdc, IB = 0 -36 -40 — V Input Capacitance CEBO IC = 0 mA, VEB = 0 V — 6 — pF 1. All specifications are subject to change without notice. 2. Unless otherwise noted, TA = 25ºC. 3. Stresses above those listed under "Absolute Maximum Ratings" may cause permanent damage to the device. These are stress ratings only; the functional operation of the device at these or any other conditions above those indicated in the operational sections of this sp ecification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. THAT Corporation; 45 Sumner Street; Milford, Massachusetts 01757-1656; USA Tel: +1 508 478 9200; Fax: +1 508 478 0990; Web: www.thatcorp.com Copyright © 2013, THAT Corporation. All rights reserved. Document Outline Home Features & Applications Description Ordering Information Pin Assignments Specifications Absolute Maximum Ratings NPN Electrical Characteristics PNP Electrical Characteristics Packaging and Soldering Information Package Characteristics Revision History
