Datasheet TB9084FTG (Toshiba) - 10
| Manufacturer | Toshiba |
| Description | Pre-driver for automobile |
| Pages / Page | 78 / 10 — 7.2.2. Gate Driver for FET for Reverse Polarity Protection |
| Revision | 3.0 |
| File Format / Size | PDF / 3.7 Mb |
TB9084FTG
The gate driver for FET for reverse polarity protection is a circuit that drives FET placed between the battery and 3-phase FETs. Even when the FET for reverse polarity protection is turned off with the battery correctly connected, the battery provides current to 3-phase FETs through the body diode of the FET. When the battery is reversely connected, by turning the FET off via RPPO terminal, reverse current to the battery is shut off. In addition, this product has built in a 500Ω output series resistor and a diode that shuts off reverse current from the ground of the under voltage detection circuit when reversely connected. This product is equipped with a switch that shuts off current flowing from RPPO terminal to GND via RPPO_UV in the reset state. Drive Circuit for FET for Reverse polarity Protection (Gate-Drv.RPP) The drive circuit for FET for reverse polarity protection is configured with a high-side switch. This switch is always ON as long as it has not received a disable signal (gate_dis_rpp). Battery Vcp RPP Ω (gate_dis_rpp) RPPO Control 150k 500Ω Gate-Drv.(RPP) V U_ O P RP
Fig. 7.2.2.1 Gate Driver Circuit for FET for Reverse Polarity Protection
© 2025 10 2025-07-31 Toshiba Electronic Devices & Storage Corporation Rev. 3.0 Document Outline 1. Description 2. Applications 3. Features 4. Block Diagram 5. Pin Assignments Top view 6. Pin Description 7. Functional Description 7.1. Charge Pump Circuit 7.2. Gate Driver Circuits 7.2.1. Gate Drivers for Driving 3-Phase FETs 7.2.2. Gate Driver for FET for Reverse Polarity Protection 7.3. Current Sensing Circuit 7.3.1. Configuration 7.3.2. Offset Calibration 7.4. Oscillation Circuit 7.5. Abnormality Flag Output Function 7.5.1. NDIAG Terminal Output 7.5.2. Status Registers in SPI communication 7.6. Abnormality Detection Circuits 7.6.1. VCC Under Voltage Detection Function 7.6.2. VB Under Voltage Detection Function 7.6.3. RPPO Under Voltage Detection Function 7.6.4. VCC Over Voltage Detection Function 7.6.5. VCP Over Voltage Detection Function 7.6.6. Over temperature Detection Function 7.6.7. VDS Detection Function for 3-Phase FETs 7.6.8. Abnormality Detection for CP1SW and CP2SW Terminals 7.7. Alarm Input Circuit 7.8. SPI Communication Circuit 7.8.1. SPI Communication Operation 7.8.2. Error Judgment 7.8.3. Register Map 7.8.3.1. CONFIG1 Write Address=2h / Read Address=3h 7.8.3.2. CONFIG2 Write Address=4h / Read Address=5h 7.8.3.3. CONFIG3 Write Address=6h / Read Address=7h 7.8.3.4. CONFIG4 (Write Address=8h / Read Address=9h 7.8.3.5. CONFIG5 Write Address=Ah / Read Address=Bh 7.8.3.6. STAT1 / Read Address=Dh 7.8.3.7. STAT2 / Read Address=Fh 7.8.3.8. STAT1_CLR Write Address=10h 7.8.3.9. STAT2_CLR Write Address=12h 7.8.3.10. NOP Write Address=Fh / Read Address=Fh 8. Absolute Maximum Ratings (Ta = 25 C) 9. Electrical Characteristics 9.1. Operating Voltage Ranges 9.2. Consumption Current 9.3. Charge Pump Circuit 9.4. Gate Driver Circuits 9.5. Current Sense Amplifier Circuit 9.6. Oscillation Circuit 9.7. Abnormality Detection Circuits 9.8. Alarm Input Circuit 9.9. SPI Communication Circuit 10. Application Circuit Example 11. Package Outlines 12. Revision History 13. Abbreviation Collection RESTRICTIONS ON PRODUCT USE
