Datasheet MAX1614 (Analog Devices)
DescriptionHigh-Side, n-Channel MOSFET Switch Driver
Pages / Page9 / 1 — MAX1614. High-Side, n-Channel MOSFET. Switch Driver. General Description. …
MAX1614. High-Side, n-Channel MOSFET. Switch Driver. General Description. Benefits and Features. Ordering Information. Applications
Datasheet MAX1614 Analog Devices
MAX1614 High-Side, n-Channel MOSFET Switch Driver General Description Benefits and Features
The MAX1614 drives high-side, n-channel power ● Integration Provides a Simple-to-Use Solution MOSFETs to provide battery power-switching functions • Requires No External Components in portable equipment. The n-channel power MOSFETs • Internal On/Off Latch Facilitates Pushbutton typically have one-third the on-resistance of p-channel Control MOSFETs of similar size and cost. An internal micropower • 1.5% Accurate Low-Battery Detector Protects regulator and charge pump generate the high-side drive Battery and Data Stored in Memory output voltage, while requiring no external components. • Controlled Turn-On for Low Inrush Current The MAX1614 also features a 1.5%-accurate low-battery ● Low Power Consumption Extends Battery Life comparator that can be used to indicate a low-battery • 25µA (max) Quiescent Current condition, provide an early power-fail warning to the • 6µA (max) Shutdown Current system microprocessor, or disconnect the battery from the load, preventing deep discharge and battery damage. An ● µMAX Package is 60% Smaller Than Typical 8-Pin internal latch allows for pushbutton on/off control with very SO Solution low current consumption. Off-mode current consumption ● Supports Typical Requirements of Portable, Battery- is only 6μA while normal operation requires less than Powered Designs 25μA. The MAX1614 is available in the space-saving • 5V to 26V Input Voltage Range μMAX® package that occupies about 60% less space • Drives Single or Back-to-Back MOSFETs than a standard 8-pin SO.
Ordering Information Applications PART TEMP RANGE PIN-PACKAGE
● Notebook Computers ● Portable Equipment MAX1614C/D 0°C to +70°C Dice* ● Hand-Held Instruments MAX1614EUA+ -40°C to +85°C 8 µMAX ● Battery Packs *Contact factory for dice specifications. +Denotes a lead(Pb)-free/RoHS-compliant package.
Typical Operating Circuit
Devices are also available in a tape-and-reel package. Specify tape-and-reel by adding “T” to the part number when μMAX is a registered trademark of Maxim Integrated Products, N N LOAD Inc. ordering. OPTIONAL FOR REVERSE CURRENT
Pin Configuration
GATE SRC PROTECTION
MAX1614
ON BATT OFF TOP VIEW R1 LBO ON 1
8 BATT LBI OFF 2 7 SRC
MAX1614
R2 LBO 3 6 GATE GND LBI 4 5 GND
µMAX
μMAX is a registered trademark of Maxim Integrated Products, Inc. 19-1176; Rev 3; 5/15
