Datasheet NC7SZ14 (ON Semiconductor)
ManufacturerON Semiconductor
DescriptionTinyLogic UHS Inverter with Schmitt Trigger Input
Pages / Page11 / 1 — DATA SHEET. www.onsemi.com. MARKING. DIAGRAMS. SIP6. CASE 127EB. …
File Format / SizePDF / 552 Kb
DATA SHEET. www.onsemi.com. MARKING. DIAGRAMS. SIP6. CASE 127EB. Description. onsemi. UDFN6. CASE 517DP. SC−74A. Features. CASE 318BQ. SOT23−5
Datasheet NC7SZ14 ON Semiconductor
link to page 5 link to page 5
DATA SHEET www.onsemi.com
MARKING DIAGRAMS
NC7SZ14
SIP6
B6KK
CASE 127EB
XYZ
The NC7SZ14 is a single inverter with Schmitt trigger input from Pin 1
onsemi
’s Ultra−High Speed (UHS) series of TinyLogic. The device is fabricated w ith advanced CMOS technology to achieve ultra−high
UDFN6
B6KK speed with high output drive while maintaining low static power
CASE 517DP
XYZ dissipation over a very broad VCC operating range. The device is specified to operate over the 1.65 V to 5.5 V VCC range. The inputs Pin 1 and outputs are high−impedance when VCC is 0 V. Inputs tolerate voltages up to 5.5 V independent of VCC operating voltage.
SC−74A Features CASE 318BQ
7Z14M G G • Ultra−High Speed: tPD = 3.7 ns (Typical) into 50 pF at 5 V VCC • High Output Drive: ±24 mA at 3 V VCC • Broad VCC Operating Range: 1.65 V to 5.5 V • Matches Performance of LCX when Operated at 3.3 V V
SOT23−5
CC
CASE 527AH
7Z14 M • Power Down High Impedance Inputs / Outputs • Over−Voltage Tolerance Inputs Facilitate 5 V to 3 V Translation • Proprietary Noise / EMI Reduction Circuitry • Ultra−Small MicroPak™ Packages Z14M G • Space−Saving SOT23−5, SC−74A and SC−88A Packages
SC−88A CASE 419A−02
G • These Devices are Pb−Free, Halogen Free/BFR Free and are RoHS Compliant IEEC / IEC B6, 7Z14, Z14 = Specific Device Code KK = 2−Digit Lot Run Traceability Code A 1 Y XY = 2−Digit Date Code Format Z = Assembly Plant Code M = Date Code
Figure 1. Logic Symbol
G = Pb−Free Package (Note: Microdot may be in either location)
ORDERING INFORMATION
See detailed ordering, marking and shipping information in the package dimensions section on page 5 of this data sheet. NOTE: Some of the devices on this data sheet have been
DISCONTINUED
. Please refer to the table on page 5. © Semiconductor Components Industries, LLC, 1996
1
Publication Order Number:
August, 2024 − Rev. 7 NC7SZ14/D
