Datasheet NC7SZ14 (ON Semiconductor) - 8
ManufacturerON Semiconductor
DescriptionTinyLogic UHS Inverter with Schmitt Trigger Input
Pages / Page11 / 8 — PACKAGE DIMENSIONS. SC−88A (SC−70−5/SOT−353). SCALE 2:1. GENERIC MARKING. …
File Format / SizePDF / 552 Kb
PACKAGE DIMENSIONS. SC−88A (SC−70−5/SOT−353). SCALE 2:1. GENERIC MARKING. DIAGRAM*. DOCUMENT NUMBER: 98ASB42984B. DESCRIPTION:
PACKAGE DIMENSIONS SC−88A (SC−70−5/SOT−353) SCALE 2:1 GENERIC MARKING DIAGRAM* DOCUMENT NUMBER: 98ASB42984B DESCRIPTION:
MECHANICAL CASE OUTLINE
CASE 419A−02 ISSUE M
SCALE 2:1
DATE 11 APR 2023
*This information is generic. Please refer to device data sheet for actual part marking. XXXMG Pb−Free indicator, “G” or microdot “G”, may G or may not be present. Some products may not follow the Generic Marking. XXX = Specific Device Code M = Date Code G = Pb−Free Package (Note: Microdot may be in either location) STYLE 1: STYLE 2: STYLE 3: STYLE 4: STYLE 5: PIN 1. BASE PIN 1. ANODE PIN 1. ANODE 1 PIN 1. SOURCE 1 PIN 1. CATHODE 2. EMITTER 2. EMITTER 2. N/C 2. DRAIN 1/2 2. COMMON ANODE 3. BASE 3. BASE 3. ANODE 2 3. SOURCE 1 3. CATHODE 2 4. COLLECTOR 4. COLLECTOR 4. CATHODE 2 4. GATE 1 4. CATHODE 3 5. COLLECTOR 5. CATHODE 5. CATHODE 1 5. GATE 2 5. CATHODE 4 STYLE 6: STYLE 7: STYLE 8: STYLE 9: Note: Please refer to datasheet for PIN 1. EMITTER 2 PIN 1. BASE PIN 1. CATHODE PIN 1. ANODE 2. BASE 2 2. EMITTER 2. COLLECTOR 2. CATHODE style callout. If style type is not called 3. EMITTER 1 3. BASE 3. N/C 3. ANODE out in the datasheet refer to the device 4. COLLECTOR 4. COLLECTOR 4. BASE 4. ANODE 5. COLLECTOR 2/BASE 1 5. COLLECTOR 5. EMITTER 5. ANODE datasheet pinout or pin assignment.
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: SC−88A (SC−70−5/SOT−353) PAGE 1 OF 1 onsemi
and are trademarks of Semiconductor Components Industries, LLC dba
onsemi
or its subsidiaries in the United States and/or other countries.
onsemi
reserves the right to make changes without further notice to any products herein.
onsemi
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does
onsemi
assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
onsemi
does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2018 www.onsemi.com
