Datasheet TC4S584F (Toshiba)
ManufacturerToshiba
DescriptionL-MOS Standard series
Pages / Page5 / 1 — TC4S584F. Absolute Maximum Ratings. (Ta = 25 °C) (Note). Marking Pin …
File Format / SizePDF / 403 Kb
TC4S584F. Absolute Maximum Ratings. (Ta = 25 °C) (Note). Marking Pin Assignment. Logic Diagram
Datasheet TC4S584F Toshiba
TC4S584F
TC4S584F TOSHIBA CMOS Digital Integrated Circuit Silicon Monolithic
TC4S584F
Schmitt Trigger TC4S584F is the one circuit inverter having the Schmitt trigger function at the input terminal. That is, since the circuit threshold level voltage at the leading and trailing edges of input waveform are different (VP, VN), the TC4S584F can be used in the broad range applications, including line receivers, waveform shaping circuit, astable multivibrators, and monostable multivibrators. Weight
Absolute Maximum Ratings (Ta = 25 °C) (Note)
SSOP5-P-0.95 : 0.016 g (typ.) Characteristics Symbol Rating Unit DC supply voltage VDD VSS − 0.5 to VSS + 20 V Input voltage VIN VSS − 0.5 to VDD + 0.5 V Output voltage VOUT VSS − 0.5 to VDD + 0.5 V DC input current IIN ±10 mA Power dissipation PD 200 mW Operating temperature range Topr −40 to 85 °C Storage temperature range Tstg −65 to 150 °C Lead temperature (10 s) TL 260 °C Note: Exceeding any of the absolute maximum ratings, even briefly, lead to deterioration in IC performance or even destruction. Using continuously under heavy loads (e.g. the application of high temperature/current/voltage and the significant change in temperature, etc.) may cause this product to decrease in the reliability significantly even if the operating conditions (i.e. operating temperature/current/voltage, etc.) are within the absolute maximum ratings and the operating ranges. Please design the appropriate reliability upon reviewing the Toshiba Semiconductor Reliability Handbook (“Handling Precautions”/“Derating Concept and Methods”) and individual reliability data (i.e. reliability test report and estimated failure rate, etc).
Marking Pin Assignment Logic Diagram
Start of commercial production 1988-05 © 2023 1 2023-10-10 Toshiba Electronic Devices & Storage Corporation Rev.1.0
