Datasheet RA6W1 (Renesas) - 8
ManufacturerRenesas
DescriptionHighly Integrated Ultra-Low Power Dual-Band Wi-Fi 6 Arm Cortex-M33 MCU
Pages / Page527 / 8 — RA6W1 Datasheet. Tables
File Format / SizePDF / 11.3 Mb
RA6W1 Datasheet Tables
link to page 31
RA6W1 Datasheet
Figure 27. Master-Transmitter protocol ... 86 Figure 28. Master-Receiver protocol ... 86 Figure 29. START byte transfer ... 87 Figure 30. Multiple Master arbitration .. 88 Figure 31. Multiple master clock synchronization .. 88 Figure 32. DAI block diagram .. 89 Figure 33. DAI Master and Slave modes ... 90 Figure 34. I2S format .. 91 Figure 35. DSP format ... 91 Figure 36. Left-justified format ... 92 Figure 37. Right-justified format... 92 Figure 38. TDM configuration .. 92 Figure 39. Two devices in LJF mode with TDM mode active .. 93 Figure 40. One device in DSP mode with offset from TDM mode ... 93 Figure 41. SPI block diagram .. 95 Figure 42. SPI timing (CPOL = 0, CPHA = 0) .. 96 Figure 43. SDIO slave block diagram .. 97 Figure 44. SDIO slave timing diagram ... 98 Figure 45. SDIO pull-up resistor .. 98 Figure 46. SD/eMMC block diagram ... 99 Figure 47. SD/eMMC host timing diagram .. 99 Figure 48. OQSPI flash controller block diagram .. 101 Figure 49. Erase suspend/resume in Auto mode .. 103 Figure 50. Quad SPI RAM/Flash controller ... 105 Figure 51. Erase suspend/resume in Auto mode .. 107 Figure 52. QSPI split burst timing for low power (QSPI_FORENSEQ_EN = 1) .. 108 Figure 53. QSPI burst timing for high performance (QSPI_FORENSEQ_EN = 0) ... 108 Figure 54. General purpose timers block diagram .. 109 Figure 55. ADC control block diagram ... 115 Figure 56. 12-bit ADC timing diagram ... 115 Figure 57. Bluetooth coexistence interface (antenna switch) .. 117 Figure 58. Typical coexistence configuration of RA6W1 with Bluetooth LE and Zigbee... 118 Figure 59. Antenna switching internal block diagram .. 118 Figure 60. Antenna switching timing diagram .. 119 Figure 61. Typical Wi-Fi application – FCQFN .. 120 Figure 62. Typical Wi-Fi application – WLCSP .. 121 Figure 63. Wi-Fi application with FEM – FCQFN .. 122 Figure 64. Wi-Fi application with FEM – WLCSP .. 123 Figure 65. Typical Wi-Fi and Bluetooth combo application – FCQFN ... 124 Figure 66. Typical Wi-Fi and Bluetooth combo application – WLCSP .. 125 Figure 67. Wi-Fi and Bluetooth combo application with FEM – FCQFN ... 126 Figure 68. Wi-Fi and Bluetooth combo application with FEM – WLCSP ... 127 Figure 69. FCQFN66 package outline drawing ... 519 Figure 70. WLCSP70 package outline drawing ... 520
Tables
Table 1: Product list ... 31 R19DS0136EK0100 Rev. 1.00 Page 8 Nov 26, 2025 CFR0011-120-00 Document Outline Features Applications Contents Figures Tables 1. Terms and Definitions 2. Block Diagrams 3. Part Numbering 4. RA6W1 Product Group 5. Pin Information 5.1 FCQFN Pinout 5.2 WLCSP Pinout 5.3 Pin Descriptions 6. Specifications 6.1 Absolute Maximum Ratings 6.2 Recommended Operating Conditions 6.3 DC Characteristics 6.4 Crystal Oscillator 40 MHz – Recommended Operating Conditions 6.5 XTAL32K – Recommended Operating Conditions 6.6 GPADC – DC Characteristics 6.7 GPADC – Electrical Performance 6.8 RST_N Digital I/O – Recommended Operating Conditions 6.9 GPIO – Recommended Operating Conditions 6.10 GPIO – DC Characteristics 6.11 Radio 6.11.1 wlCSP Package WLAN Radio Characteristics 6.11.2 QFN Package WLAN Radio Characteristics 7. System Overview 8. Core System 8.1 Arm Cortex-M33 8.1.1 Introduction 8.1.2 Interrupts 8.1.3 Debug 8.2 Internal Memory Architecture 8.2.1 Introduction 8.2.2 ROM 8.2.3 System RAM 8.2.4 Retention RAM 8.2.5 OTP 8.2.6 System Address Map 8.3 Clock Generation 8.3.1 Introduction 8.3.2 System Clock (SYS_CLK, HCLK) 8.3.3 Peripheral Clocks (SPI_CLK, PERI_CLK, AUX_CLK) 8.3.4 Audio Clocks (AUD_CLK) 8.3.5 RTC Clocks (32 kHz) 8.4 Power Management 8.4.1 Power-On Sequence 8.4.2 Power Management Unit 8.5 Sleep Modes 8.5.1 Introduction 8.5.2 Wake-Up Sources 8.5.3 Sleep Mode Active Blocks Overview 8.6 DMA 8.6.1 Introduction 8.6.2 General Purpose DMA 8.6.2.1 Input/Output Multiplexer 8.6.2.2 DMA Channel Operation 8.6.2.3 DMA Arbitration 8.6.2.4 Freezing DMA Channels 8.6.3 Fast DMA 8.7 Hardware Accelerators 8.7.1 CRC Calculation 8.7.2 Pseudo Random Number Generation 8.8 Watchdog Timer 8.8.1 Introduction 8.9 Brownout and Blackout Detection 8.10 Security Features 8.10.1 Crypto Engine 8.11 Debug Support 9. Peripherals 9.1 UART 9.1.1 Introduction 9.1.2 RS-232 9.1.3 RS-485 9.1.4 Baud Rate 9.1.5 Hardware Flow Control 9.1.6 Interrupts 9.1.7 DMA Interface 9.1.8 Pin Configuration 9.2 I2C Interface 9.2.1 Introduction 9.2.2 I2C Behavior 9.2.2.1 START and STOP Generation 9.2.2.2 Combined Formats 9.2.3 I2C Protocols 9.2.3.1 START and STOP Conditions 9.2.3.2 Addressing Slave Protocol 9.2.3.2.1 7-bit Address Format 9.2.3.2.2 10-bit Address Format 9.2.3.3 Transmitting and Receiving Protocols 9.2.3.3.1 Master-Transmitter and Slave-Receiver 9.2.3.3.2 Master-Receiver and Slave-Transmitter 9.2.3.3.3 START Byte Transfer Protocol 9.2.4 Multiple Master Arbitration 9.2.5 Clock Synchronization 9.3 Digital Audio Interface (I2S and PDM) 9.3.1 Introduction 9.3.2 Interface Signals 9.3.3 Master and Slave Modes 9.3.4 DAI Slots 9.3.5 DAI Slot Formats 9.3.5.1 I2S Format 9.3.5.2 DSP Format 9.3.5.3 Left-Justified Format 9.3.5.4 Right-Justified Format 9.3.5.5 Time Division Multiplexing Mode 9.3.6 DAI Slot Assignment 9.3.7 DAI PCM_CLK Generation 9.4 SPI Master/Slave 9.4.1 Introduction 9.4.2 SPI Timing 9.5 SDIO 9.5.1 Introduction 9.6 SD/eMMC Host Controller 9.6.1 Introduction 9.7 Octa/Quad SPI Flash Controller – With Secure XIP 9.7.1 Introduction 9.7.1.1 Interface 9.7.1.2 SPI Modes 9.7.1.3 Access Modes 9.7.1.3.1 Auto Mode 9.7.1.3.2 Manual Mode 9.7.1.4 Endianness 9.7.1.5 Erase Suspend/Resume 9.7.1.6 On-the-fly Decryption 9.8 Quad SPI RAM/Flash Controller – PSRAM 9.8.1 Introduction 9.8.2 Interface 9.8.3 SPI Modes 9.8.4 Access Modes 9.8.4.1 Auto Mode Flash Access 9.8.4.2 Auto Mode RAM Access 9.8.4.3 Manual Mode 9.8.5 Endianness 9.8.6 Erase Suspend/Resume 9.8.7 Low Power Considerations 9.9 General Purpose Timers/PWMs 9.9.1 Introduction 9.9.2 Timer Modes of Operation 9.9.2.1 Free-Running Counter 9.9.2.2 PWM Generation 9.9.2.3 Event Capturing 9.9.2.4 One Shot 9.9.2.5 GPIO Pulse Counter 9.9.3 Pin Configuration 9.10 GPIOs and Programmable Pin Assignment 9.11 ADC/Analog or ADC (Aux 12-bit) 9.11.1 Introduction 9.11.2 Timing Diagram 9.11.3 DMA Transfer 9.11.4 Sensor Wake-up 9.11.5 ADC Pin Configuration 9.12 Bluetooth LE/Zigbee Coexistence 9.12.1 One External Radio Coexistence Interface 9.12.2 Two External Radios Coexistence Interface 9.13 Antenna Switching Diversity 9.13.1 Introduction 10. Application Information 10.1 Wi-Fi Application 10.1.1 Typical Wi-Fi Application – FCQFN 10.1.2 Typical Wi-Fi Application – WLCSP 10.1.3 Wi-Fi Application with FEM – FCQFN 10.1.4 Wi-Fi Application with FEM – WLCSP 10.2 Wi-Fi and Bluetooth Combo Application 10.2.1 Typical Wi-Fi and Bluetooth Combo Application – FCQFN 10.2.2 Typical Wi-Fi and Bluetooth Combo Application – WLCSP 10.2.3 Wi-Fi and Bluetooth Combo Application with FEM – FCQFN 10.2.4 Wi-Fi and Bluetooth Combo Application with FEM – WLCSP 11. Registers 11.1 APU Registers 11.2 CACHE Registers 11.3 CRG Registers 11.4 CRG APU Registers 11.5 CRG PREG Registers 11.6 DAI Registers 11.7 DCACHE Registers 11.8 DMA Registers 11.9 GPIO Registers 11.10 General Purpose System Status Registers 11.11 I2C Registers 11.12 KDMA Registers 11.13 MEMCTRL Registers 11.14 OQSPI Registers 11.15 QSPI Registers 11.16 Retention Memory Control Registers 11.17 RTC Registers 11.18 SD/EMMC Registers 11.19 SDIO Registers 11.20 SPI Registers 11.21 SPI2 Registers 11.22 Source FIFO Registers 11.23 Source Interface Registers 11.24 Watchdog Timer Control Registers 11.25 AHB DMA Registers 11.26 AHB Arbitration Registers 11.27 Timer6 Registers 11.28 Timer Control Registers 11.29 Timer2 Control Registers 11.30 Timer3 Control Registers 11.31 Timer4 Control Registers 11.32 Timer5 Control Registers 11.33 Timer7 Control Registers 11.34 Timer8 Control Registers 11.35 UART Registers 11.36 UART2 Registers 11.37 ID Registers 12. Package Information 12.1 Moisture Sensitivity Level (MSL) 12.2 WLCSP Handling 12.3 Soldering Information 12.4 Package Outline Drawings 13. Revision History Appendix A ECAD Design Information A.1 Part Number Indexing A.2 Symbol Pin Information A.2.1 66-QFN A.2.2 70-WLCSP A.3 Symbol Parameters A.4 Footprint Design Information A.4.1 66-QFN A.4.2 70-WLCSP
