Datasheet MAX5048 (Analog Devices) - 3
Description7.6A, 12ns, SOT23/TDFN MOSFET Driver
Pages / Page11 / 3 — MAX5048. 7.6A, 12ns, SOT23/TDFN, MOSFET Driver. ELECTRICAL …
File Format / SizePDF / 268 Kb
MAX5048. 7.6A, 12ns, SOT23/TDFN, MOSFET Driver. ELECTRICAL CHARACTERISTICS (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX
MAX5048 7.6A, 12ns, SOT23/TDFN, MOSFET Driver ELECTRICAL CHARACTERISTICS (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX
(V+ = +12V, TA = -40°C to +125°C, unless otherwise noted. Typical values are at TA = +25°C.) (Note 3)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
V+ = 0 or unconnected, I Power-Off Pulldown Resistance N-OUT = -10mA, 3.3 10 Ω TA = +25°C Power-Off Pulldown Clamp V+ = 0 or unconnected, IN-OUT = -10mA, 0.85 1.0 V Voltage TA = +25°C Output Leakage Current ILK-N N_OUT = V+ 6.85 20 µA Peak Output Current (Sinking) IPK-N CL = 10,000pF 7.6 A
p-CHANNEL OUTPUT
V TA = +25°C 2.00 3.00 V+ = +10V, Driver Output Resistance— IP-OUT = 50mA TA = +125°C 2.85 4.30 Pulling Up (MAX5048AAUT/ RON-P Ω T V A = +25°C 2.20 3.30 MAX5048BAUT) V+ = +4.5V, IP-OUT = 50mA TA = +125°C 3.10 4.70 V TA = +25°C 2.08 3.08 V+ = +10V, Driver Output Resistance— IP-OUT = 50mA TA = +125°C 2.93 4.38 Pulling Up (MAX5048AATT/ RON-P Ω V TA = +25°C 2.28 3.38 MAX5048BATT) V+ = +4.5V, IP-OUT = 50mA TA = +125°C 3.18 4.78 Output Leakage Current ILK-P P_OUT = 0 0.001 10 µA Peak Output Current (Sourcing) IPK-P CL = 10,000pF 1.3 A
LOGIC INPUT
MAX5048A 0.67 x V+ Logic 1 Input Voltage VIH V MAX5048B 2.4 MAX5048A 0.33 x V+ Logic 0 Input Voltage VIL V MAX5048B 0.8 MAX5048A 1.6 Logic-Input Hysteresis VHYS V MAX5048B 0.68 Logic-Input Current VIN_ = V+ or 0 0.001 10 µA Input Capacitance CIN 2.5 pF
SWITCHING CHARACTERISTICS FOR V+ = +10V
CL = 1000pF 8 Rise Time tR CL = 5000pF 45 ns CL = 10,000pF 82 CL = 1000pF 3.2 Fall Time tF CL = 5000pF 7.5 ns CL = 10,000pF 12.5 Turn-On Propagation Delay Time tD-ON Figure 1, CL = 1000pF (Note 4) 7 12 25 ns Turn-Off Propagation Delay Time tD-OFF Figure 1, CL = 1000pF (Note 4) 7 12 25 ns Break-Before-Make Time 2.5 ns Maxim Integrated 3
