Datasheet DXTN78060DFG (Diodes)
| Manufacturer | Diodes |
| Description | NPN, 60V, 6A, PowerDI3333-8 |
| Pages / Page | 8 / 1 — DXTN78060DFG. 60V NPN ULTRA-LOW VCE(sat) TRANSISTOR IN PowerDI3333-8. … |
| File Format / Size | PDF / 541 Kb |
DXTN78060DFG. 60V NPN ULTRA-LOW VCE(sat) TRANSISTOR IN PowerDI3333-8. Features. Mechanical Data. Applications
DXTN78060DFG 60V NPN ULTRA-LOW VCE(sat) TRANSISTOR IN PowerDI3333-8 Features Mechanical Data
• BVCEO > 60V • Package: PowerDI®3333-8 • BVEBO > 8V • Package Material: Molded Plastic. “Green” Molding • Continuous Current IC to 6A Compound UL Flammability Rating 94V-0 • Peak Pulse Current ICM to 12A • Moisture Sensitivity: Level 1 per J-STD-020 • Ultra-Low Saturation Voltage VCE(sat) < 45mV @ 1A • Terminals: Finish - Matte Tin. • High Current RCE(sat) = 23mΩ Typical Solderable per MIL-STD-202, Method 208 • Small Form Factor Thermally Efficient Package Enables Higher • Weight: 0.03 grams (Approximate) Density End Products • Wettable Flank for Improved Optical Inspection
Applications
• Rated to +175°C – Ideal for High-Temperature Environments • Complementary PNP Type: DXTP78060DFG • MOSFET & IGBT gate drivers •
Lead-Free Finish; RoHS Compliant (Notes 1 & 2)
• Load switches •
Halogen and Antimony Free. “Green” Device (Note 3)
• Low-voltage regulation •
An automotive-compliant part is available under a separate
• DC to DC converters
datasheet (DXTN78060DFGQ)
• Motor, solenoid, relay and actuator drivers control PowerDI3333-8/SWP (Type UX) C C C C B E E E Pin 1 Top View Bottom View Device Symbol
Ordering Information
(Note 4)
Packing Orderable Part Number Package Marking Reel Size (inches) Tape Width (mm) Qty. Carrier
PowerDI3333-8/SWP DXTN78060DFG-7 2Y0 7 12 2,000 Reel (Type UX) Notes: 1. EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. All applicable RoHS exemptions applied. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/.
Marking Information
W
2Y0 = Product Type Marking Code
W
YYWW = Date Code Marking
Y
YY = Last Two Digits of Year (ex: 25 = 2025)
Y
WW = Week Code (01 to 53)
2Y0
PowerDI is a registered trademark of Diodes Incorporated in the United States and other countries. DXTN78060DFG 1 of 8 August 2025 Document number: DS46860 Rev. 2 - 2
www.diodes.com
