Datasheet PAM8406 (Diodes)
| Manufacturer | Diodes |
| Description | 5W Stereo Audio Amplifier with Class D/AB Switch |
| Pages / Page | 13 / 1 — PAM8406. ALTERNATIVE 5W STEREO AUDIO AMPLIFIER. Description. Pin … |
| File Format / Size | PDF / 1.6 Mb |
PAM8406. ALTERNATIVE 5W STEREO AUDIO AMPLIFIER. Description. Pin Assignments. Features. Applications
PAM8406 ALTERNATIVE 5W STEREO AUDIO AMPLIFIER Description Pin Assignments
The PAM8406 is a 5W audio amplifier with an alternative option between Class-D and Class-AB output, which makes the device very 16 ideal for efficiency-EMI compatible applications. 1 +OUT_L XATYWWLL PAM +OUT_R The PAM8406’s low THD+N and high SNR allow it to achieve high- PGNDL PGNDR quality sound reproduction. The device’s fully differential output with -OUT_L -OUT_R new filter-less architecture (Class-D Mode) allows the device to drive 8406 the speaker directly, requiring no low-pass output filters and DC PVDDL PVDDR blocking capacitors, thus saving system cost and PCB area. MUTE SHDN The device has an efficiency of up to 90%. It can extend battery life, GND which is ideal for portable applications. It is fully protected against VDD faults with short-circuit protection and thermal protection. INL INR The PAM8406 is available in the SOP-16L/SOP-16(EP) package. 8 9 VREF MODE
Features Applications
• Alternative Output: Class-D or Class-AB • LCD TVs • 5W Output at 10% THD with a 2Ω Load and 5V Power Supply at • Multimedia Speakers Class-D Mode • AM/FM Systems • 3W Output at 10% THD with a 4Ω Load and 5V Power Supply • DABs • Filterless, Low Quiescent Current and No EMI • Low THD+N at Fully Output Range • Superior Low Noise • Efficiency up to 90% with Class-D Mode • No Pop At Turn-On/Off • Full Short-Circuit Protection With Auto Recovery • Thermal Shutdown • Few External Components to Save Space and Cost •
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
Halogen- and Antimony-Free. “Green” Device (Note 3)
For automotive applications requiring specific change control (i.e. parts qualified to AEC-Q100/101/200, PPAP capable, and manufactured in IATF 16949 certified facilities), please contact us or your local Diodes representative. https:/ www.diodes.com/quality/product-definitions/
Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. PAM8406 1 of 13 May 2021 Document number: DS43342 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated Document Outline Pin Assignments Description Applications Features
