Datasheet TS2937 (Taiwan Semiconductor)
ManufacturerTaiwan Semiconductor
Description500mA Ultra Low Dropout Voltage Regulator
Pages / Page10 / 1 — TS2937. 500mA Ultra Low Dropout Voltage Regulator. TO-220. TO-263 …
File Format / SizePDF / 367 Kb
TS2937. 500mA Ultra Low Dropout Voltage Regulator. TO-220. TO-263 (D2PAK). TO-252 (DPAK). SOT-223. Pin Definition:. Notes:
Datasheet TS2937 Taiwan Semiconductor
TS2937
DESCRIPTION FEATURES TS2937 of fixed-voltage monolithic micro-power voltage ● Dropout voltage typically 0.6V @ Io=500mA regulators is designed for a wide range of applications. ● Output voltage trimmed before assembly This device excellent choice of use in battery-power ● -18V Reverse peak voltage application. Furthermore, the quiescent current ● +30V Input over voltage protection increases on slightly at dropout, which prolongs battery ● +60V Transient peak voltage life. This series of fixed-voltage regulators features very ● Internal current limit low ground current (200uA Typ.) and very low drop ● Thermal shutdown protection output voltage (Typ. 60mV at light load and 600mV at APPLICATION 500mA). This includes a tight initial tolerance of 2%, ● Post Regulator for SMPS extremely good line regulation of 0.05% typ., and very ● Industrial Instrumentation low output temperature coefficient.
TO-220 TO-263 (D2PAK) TO-252 (DPAK) SOT-223 Pin Definition:
1. Input 2. Ground 3. Output
Notes:
Moisture sensitivity level: level 3. Per J-STD-020 TYPICAL APPLICATION CIRCUIT Document Number: DS_P0000215 1 Version: E15
