Datasheet PM2105L (Cubic) - 8
ManufacturerCubic
DescriptionLow Power Particle Sensor
Pages / Page16 / 8 — Temperature Influence Curve
File Format / SizePDF / 627 Kb
Particle measured error: under 25±2℃, 0~1,000μg/m³, consistency and accuracy of PM1.0/PM2.5 is either ±15% reading or ±15μg/m³, the bigger one is considered. Temperature influence coefficient: 0.5%/℃ ~ 1%/℃ or 0.5μg/m³/℃ ~ 1μg/m³/℃, the bigger one is considered. www.en.gassensor.com.cn 7/19 Document Outline Description Features Working Principle Specifications Dimensions and Connector 1.Dimensions (Unit mm, tolerance ±0.2 mm) Typical Application Circuit Case 1.UART3.3V Application Product Installation User Attention UART Communication Protocol 1. General Statement 2.Format of Serial Communication Protocol 3.Command Table of Serial Protocol Note: Example: 4.3 Set up and Read Particle Calibrated Coefficien Note: Description: 4.4 Close/Open Laser Diode Note: Note: Example: Note: Example: I²C Communication Protocol 1. Brief Introduction 2. Communication Common Description 3. Protocol Detailed Description 3.1Send Command Data 3.2Read Command Data Packing Information
