Datasheet S6846 (Hamamatsu)
ManufacturerHamamatsu
Pages / Page10 / 1 — Light modulation photo IC. S4282-51, S6809, S6846, S6986, S7136/-10, …
File Format / SizePDF / 680 Kb
Light modulation photo IC. S4282-51, S6809, S6846, S6986, S7136/-10, S10053/-01DT
Datasheet S6846 Hamamatsu
Fewer detection errors even under disturbance
background light
These light modulation photo ICs were developed for optical synchronous detection under disturbance background light.
A photodiode, preamplifier, comparator, oscillator, LED driver and signal processing circuit, etc. are all integrated on
a monolithic photo IC chip. Optical synchronous type photoreflectors and photointerrupters, which less susceptible to
disturbance background light, can be easily configured by just connecting an external LED to this photo IC. Our unique circuit
design achieves an allowable background light level of 10000 lx typ. (S4282-51, S6986, S10053/-01DT) and a minimum
detection level of 0.2 µW/mm2 typ. (S6809, S6846, S7136/-10). Features Applications L arge allowable background light level
S4282-51, S6986, S10053/-01DT: 10000 lx typ.
S6809, S6846, S7136/-10 : 3000 lx typ. P aper detection in office machine
(copiers, fax machines, etc.) M inimum detection level
S4282-51, S6986, S10053/-01DT: 0.7 µW/mm2 typ.
S6809, S6846, S7136/-10 : 0.2 µW/mm2 typ. Optical switches Digital output (Output appears “L” by light input.)
Small hysteresis (S6809)
S mall SMD package
S10053: stick
S10053-01DT: reel Absolute maximum ratings (Ta=25 °C)
Parameter
Supply voltage
Output voltage
Output current
Cathode output voltage
Cathode output current
Power dissipation*1
Operating temperature
Storage temperature
Soldering temperature Symbol
Vcc
Vo
Io
Vcath
Icath
P
Topr
Tstg
Tsol S10053/-01DT -25 to +85
240 (once)*2 S4282-51, S6986
-0.5 to +16
-0.5 to +16
50
-0.5 to +16
70
250
-25 to +60
-40 to +100
*3
*3 Unit
V
V
mA
V
mA
mW
°C
°C
°C Note: E xceeding the absolute maximum ratings even momentarily may cause a drop in product quality. Always be sure to use the
product within the absolute maximum ratings.
*1: Power dissipation decreases at a rate of 3.3 mW/°C above Ta=25 °C
*2: Reflow soldering, IPC/JEDEC-J-STD-020 MSL5a, see P.9
*3: See the recommended soldering conditions (P.9). www.hamamatsu.com 1
