Datasheet S6846 (Hamamatsu) - 3
| Manufacturer | Hamamatsu |
| Pages / Page | 10 / 3 |
| File Format / Size | PDF / 680 Kb |
Light modulation photo IC S4282-51, S6809, S6846, S6986, S7136/-10, S10053/-01DT Electrical and optical characteristics (Ta=25 °C, Vcc=5 V)
Parameter Symbol Condition Vcc Current consumption Icc Low level
output voltage Vo, LED terminals
open VOL IOL=16 mA High level
output voltage VOH 4.7 kΩ between
Vcc and Vo Output Supply voltage Cathode Low level
Vcath
output voltage
Low(S6986,
level S4282-51)
Equivalent circuit
Icath
output current
Pulse cycle
Tp
Pulse width
Tw
H→L threshold light level EHL Hysteresis -Frequency response f Allowable background
light level Ex Equivalent Circuit *2: Cathode S4282-51, S6986, S10053/-01DT
Output: built-in pull-up resistor*2
Cathode: constant current drive
Min.
Typ.
Max.
4.5
16 V 4 11 -4 11 mA -0.2 0.4 -0.2 0.4 V 4.9 -V
4.5 -V -0.8 V 15 35 60 65
4 130
8 220
13.7 65
4 130
8 220
13.7 μs
μs -0.7 2 -0.2 1.0 μW/mm2 0.45 0.65 0.95 0.5 1.25 -0.45
0.65
(S6809)
0.5 0.65
0.8
(S6809)
1.25 0.95
0.95
(S6809)
-kHz 5000 10000 -2000 3000 -lx λ=940 nm
No background light Signal light: 5 μW/mm2,
λp=940 nm
Background light:
“A” light source Unit -Icath=40 mA
Vcath=1.2 V S6809, S6846, S7136/-10
Output: open collector*3
Cathode: open collector drive
Min.
Typ.
Max.
4.5
16 mA -Output
Vcc
Cathode
(LED) Vcc
10 k
Vout GND GND
KPICC0009EA *3: Cathode Output
Vcc Vcc Cathode
(LED) Vout GND GND
KPICC0010EA KPICC0009EA 3
