Datasheet SLF7045 (TDK) - 5
ManufacturerTDK
DescriptionInductors for power circuits
Pages / Page5 / 5 — REMINDERS FOR USING THESE PRODUCTS. SAFETY REMINDERS. REMINDERS
File Format / SizePDF / 486 Kb
REMINDERS FOR USING THESE PRODUCTS SAFETY REMINDERS REMINDERS
I N D U C T O R S
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products
REMINDERS
◯The storage period is within 6 months. Be sure to fol ow the storage conditions (temperature: 5 to 30°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. ◯Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). ◯Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. ◯Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. ◯When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overal distortion of the printed circuit board and partial distortion such as at screw tightening portions. ◯Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. ◯Careful y lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. ◯Use a wrist band to discharge static electricity in your body through the grounding wire. ◯Do not expose the products to magnets or magnetic fields. ◯Do not use for a purpose outside of the contents regulated in the delivery specifications. ◯The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/ or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (7) Transportation control equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (8) Public information-processing equipment (3) Medical equipment (9) Military equipment (4) Power-generation control equipment (10) Electric heating apparatus, burning equipment (5) Atomic energy-related equipment (11) Disaster prevention/crime prevention equipment (6) Seabed equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specif i cati ons t hat pr ovi de f urt her det ail s on t he f eat ur es and s pecif i cat i ons of t he pr oducts for pr oper and safe use . (5/5) Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240527 inductor_commercial_power_slf7045_en
