Datasheet TCD2400DG (Toshiba) - 2
ManufacturerToshiba
DescriptionCCD Linear Image Sensor
Pages / Page15 / 2 — TCD2400DG. Features. Pin Connections (top view). ABSOLUTE MAXIMUM RATINGS …
File Format / SizePDF / 460 Kb
TCD2400DG. Features. Pin Connections (top view). ABSOLUTE MAXIMUM RATINGS (Note 1)
TCD2400DG Features Pin Connections (top view) ABSOLUTE MAXIMUM RATINGS (Note 1)
TCD2400DG TOSHIBA Linear Image Sensor CCD (Charge Coupled Device)
TCD2400DG
The TCD2400DG is a high sensitive and low dark current 4096 elements  3 lines CCD color linear image sensor. The device contains a row of 4096 elements  3 lines photodiodes are for automated optical inspection. The device is operated by 3.3 V pulse and 3.3 V & 10.0 V power supply.
Features
Number of Image Sensing Elements: 4096 elements  3 lines Image Sensing Element Size: 7 m by 7m on 7 m center WDIP32-G- 400-2.54 Photo Sensing Region: High sensitive PN photodiode Power Supply Voltage: 3.3 V & 10.0 V (typ.) 画 or 写真貼り付け予定 Distance between Photodiode Array: 28 m (4 lines) B array − G array, G array − R array Internal Circuit: Timing generator circuit, Clamp circuit, Sample and hold circuit Package: 32 pin CERDIP Color Filter: Red, Green, Blue
VSS 1 32 OS6 Characteristics Symbol Rating Unit VSS 2 31 OS5 AVDD 3 30 OS3 MCK Clock pulse voltage VMCK 1 1 1 −0.3 to +5.0 SH Clock pulse voltage V OS4 SH VSS 4 29 V OS2 AVDD −0.3 to +5.0 VDD10 5 28 V 3.3 V Power supply voltage VDVDD −0.3 to +5.0 DVDD 6 27 OS1 V CKDVDD −0.3 to +5.0 VSS 7 26 VSS 10.0 V Power supply voltage V VDD10 −0.3 to +13.5 CKDVDD 8 d e 25 CKDVDD reen lue Operating temperature T R B opr 0 to 60 G φ1A1 °C NC 9 24 NC Storage temperature Tstg −25 to +85 NC 10 23 NC Note 1: All voltages are with respect to VSS terminals (ground). NC NC None of the ABSOLUTE MAXIMUM RATINGS must be exceeded, 11 22 even instantaneously. CKDVDD 12 21 CKDVDD If any one of the ABSOLUTE MAXIMUM RATINGS is exceeded, VSS 13 20 VSS the electrical characteristics, reliability and life time of the device 4096 4096 4096 cannot be guaranteed. If the ABSOLUTE MAXIMUM RATINGS are MCK 14 19 VSS exceeded, the device can be permanently damaged or degraded. SH 15 18 VDD10 Create a system design in such a manner that any of the ABSOLUTE MAXIMUM RATINGS will not be exceeded under any VSS 16 17 DVDD circumstances. Start of commercial production 2025-09 © 2025 2 Rev.1.0 2025-09-12 Toshiba Electronic Devices & Storage Corporation
