Datasheet TCD2400DG (Toshiba) - 5
| Manufacturer | Toshiba |
| Description | CCD Linear Image Sensor |
| Pages / Page | 15 / 5 — Optical/Electrical Characteristics. 25°C, VAVDD. VDVDD. VCKDVDD. 3.3 V, … |
| File Format / Size | PDF / 460 Kb |
Optical/Electrical Characteristics. 25°C, VAVDD. VDVDD. VCKDVDD. 3.3 V, VVDD10. 10.0 V,. VMCK. VSH. 3.3 V (pulse), fMCK
TCD2400DG
Optical/Electrical Characteristics Ta
25°C, VAVDD
VDVDD
VCKDVDD
3.3 V, VVDD10
10.0 V, VMCK
VSH
3.3 V (pulse), fMCK
25 MHz, tINT (integration time)
10 ms, light source
A light source
CM500S filter (t
1.0 mm)
Characteristics Symbol Min Typ. Max Unit Note Red RR 10.2 14.7 19.2 Sensitivity Green RG 11.6 16.6 21.6 V/(lx・s) (Note 2) Blue RB 4.8 6.9 9.0 PRNU (1) ⎯ 5 20 % (Note 3) Photo response non uniformity PRNU (3) ⎯ 6 17 mV (Note 4) Saturation output voltage VSAT 0.8 0.95 ⎯ V (Note 5) Dark signal voltage VDRK ⎯ 1.8 6.0 mV (Note 6) Dark signal non uniformity DSNU ⎯ 4 15 mV (Note 7) AVDD DC power dissipation PAVDD ⎯ 145 263 mW (Note 8) CKDVDD DC power dissipation PCKDVDD ⎯ 290 455 mW (Note 8) DVDD DC power dissipation PDVDD ⎯ 132 196 mW (Note 8) VDD10 DC power dissipation PVDD10 ⎯ 150 273 mW (Note 8) Total transfer efficiency TTE 92 97 ⎯ % (Note 9) Output impedance ZO ⎯ 95 250 ⎯ DC output signal voltage VOS 1.3 1.85 2.4 V (Note 10) Random noise ND ⎯ 1.7 ⎯ mV (Note 11) Difference of output voltage as next pixel in OS Vdiff ⎯ 7 30 mV (Note 12) Note 2: Sensitivity is defined for each color of signal outputs average when the photosensitive surface is applied with the light of uniform illumination and uniform color temperature. Note 3: PRNU (1) is defined for each color on a single chip by the expressions below when the photosensitive surface is applied with the light of uniform illumination and uniform color temperature, where measured approximately 400 mV of signal output. X PRNU (1) = 100 (%) X X : Average of total signal outputs X: The maximum deviation from X Note 4: PRNU (3) is defined as the maximum voltage with next pixel, where measured approximately 50 mV of signal output. Note 5: VSAT is defined as the minimum saturation output voltage of all effective pixels. Note 6: VDRK is defined as average dark signal voltage of all effective pixels. Note 7: DSNU is defined by the difference between average value (VDRK) and the maximum value of the dark voltage. OS VDRK DSNU Note 8: DC power dissipations are defined on below condition. fMCK = 50 MHz VAVDD = VDVDD = VCKVDD = 3.5 V VVDD10 = 10.5 V © 2025 5 Rev.1.0 2025-09-12 Toshiba Electronic Devices & Storage Corporation
